USB to RJ45
Hi CEans,
my uncle used to face trouble in his shop when he wanted to connect a printer with PC, due to the distance and space constraints. I failed trying with a USB extension as the distance from PC to printer was around 25 mts. I knew that USB will last long max upto 5-7mts. Now i tried searching for USB extentions above 20mts, and i landed to USB-RJ45 converter which will boost upto 45mts(only USB2.0). But not cost effective it would reach in my hand only to cost around Rs. 5000-7000/- (i.e 125-175$). I dropped the buying option, went to electronics market got a RJ45 cable for 6$, got a RJ45 crimps worth 2$, and two RJ45 box worth 1.25$. Thats it rest of all were done. see below for connections details.
1) RJ45 BOX-1 USB CABLE
Pin# 1 +5V(RED)
Pin# 2 D- (white) <---------- USB Device
Pin# 3 D+ (Green)
Pin# 4 GND (Black)
2) RJ45 BOX-2 USB CABLE
Pin# 1 +5V(RED)
Pin# 2 D- (white) ------------> PC
Pin# 3 D+ (Green)
Pin# 4 GND (Black)
the same way you can also use this to extend VGA signals. ( Only thing is you will have to match the impedance in case of VGA) Any doubts reply back.
