Uninterrupted power supply through solar source, mains, generator and inverter
Koushal Patel
Koushal Patel
@koushal-C6mEgp Oct 25, 2024
Koushal Patel submitted a new project:
#-Link-Snipped-# - Uninterrupted power supply
This project is aimed to make uninterrupted power supply to a load. We will be using 4 sources viz. solar, mains, generator and inverted. At a single moment, only one source is active and supplies power. If that source fails, the next source becomes active.
Uses : Hospitals, Houses, Industries
8051 family micro-controller is used. The output of micro-controller is given to the relay driver IC, which switches appropriate relay to maintain uninterrupted supply to the load. The project can be...
  • Don Ross
    Don Ross
    @don-ross-A3oedi Jan 13, 2015
    How are you planning to keep the power stream from being interrupted when shifting from one source to another? ei. data centers, hospitals, critical industrial applications.
    I have an account that grows crystals and it's a 20hr. run. Now if that run is interrupted even for a minute, the run is abandoned and a $25,000 loss is occurred.
  • Koushal Patel
    Koushal Patel
    @koushal-C6mEgp Jan 14, 2015
  • Don Ross
    Don Ross
    @don-ross-A3oedi Jan 14, 2015
    How does that device sync the phases when switching over?
