Hello friends I want to know what are the types of spring? I am a mechanical engineer from TamilNadu and I am clueless about the types of strings. Please reply soon!0
Administrator • Mar 13, 2012
Unless you are looking for specifics; the following URL should give you all the information you need about the various types of springs: #-Link-Snipped-#Are you sure? This action cannot be undone. -
Member • Mar 14, 2012
Helical spring, compression spring, English Elbow spring, Leaf spring and many more.
Are you looking for design of springs or only general information?Are you sure? This action cannot be undone. -
On the subject of springs, what are the design equations looked at when deigning a spring for a particular application.Are you sure? This action cannot be undone. -
if u go for type of application of force then mainly three types- Compression spring, Tension sprng & torsion.
These are the basic types and according to applications and other constraints the springs are also given different names.Are you sure? This action cannot be undone. -
There are a number of factors affecting design of springs. The equations will vary depending on loading conditions.CE DesignerOn the subject of springs, what are the design equations looked at when deigning a spring for a particular application.
Here is something you should look for-
<a href="https://www.efunda.com/designstandards/springs/spring_introduction.cfm" target="_blank" rel="nofollow noopener noreferrer">Mechanical Design Guidelines for Springs</a>
<a href="https://www.efunda.com/DesignStandards/springs/calc_comp_designer.cfm" target="_blank" rel="nofollow noopener noreferrer">Calculator for Designing Compression Springs</a>Are you sure? This action cannot be undone. -
Member • Mar 23, 2012
the general types are coil and leaf springs
under coil springs you have compressin , tension and torsional
there is also another class called belleville and plate springs.
however the types of springs varies from application to application. compression springs can also have a taper or conical profile.Are you sure? This action cannot be undone.
