Which Type of Motor is Used in Air Cooler?
jyothirmaijo
@jyothirmaijo-yvPmoh โ€ข Oct 27, 2024
An air cooler, often referred to as a swamp cooler or evaporative cooler, typically uses an electric induction motor to drive a fan which pushes air through a water-soaked pad, thereby cooling the air through evaporation.
Let's discuss this in detail:
Induction Motor
Induction motors, also known as asynchronous motors, are a type of AC (alternating current) motor. The name 'induction' comes from the way the motor generates magnetic fields and electrical current.
The fundamental principle behind an induction motor is electromagnetic induction.
Electromagnetic induction is the process of inducing (creating) voltage in a conductor when the magnetic field around it changes.
This principle was discovered by Michael Faraday in 1831 and is also known as Faraday's law of electromagnetic induction.
Induction motors consist of two main parts: the stator and the rotor.
  1. Stator: The stator is the stationary part of the motor that is wound with a series of coils to create a magnetic field. When an AC supply is connected to the stator, it creates a rotating magnetic field.
  2. Rotor: The rotor is the part of the motor that rotates. It is typically made of laminated iron and can be of two types: the squirrel cage rotor and the wound rotor. In a common household appliance like an air cooler, a squirrel cage rotor is most likely used because it is simple, reliable, and inexpensive.
When the rotating magnetic field of the stator cuts across the bars of the rotor, a current is induced (hence the name 'induction motor').
This induced current in the rotor bars will also produce its own magnetic field.
According to Lenz's law, the direction of this magnetic field will be such that it will oppose the cause of its production.
So, it will try to catch up with the stator field, causing the rotor to rotate. However, it never synchronizes with the rotating magnetic field of the stator, hence the name 'asynchronous motor'.
As for the types of induction motors:
  1. Single-phase Induction Motor: These motors operate on a single-phase AC supply. They are smaller and are commonly used in low power applications like household appliances including air coolers. They are less complex and cheaper than three-phase motors.
  2. Three-phase Induction Motor: These motors operate on a three-phase AC supply. They are used in industrial and high-power applications as they are more efficient and provide a steadier torque than single-phase motors.
The key advantage of an induction motor is that its operation depends on a basic magnetic principle, it's simple, rugged, and requires little to no maintenance.
This makes it ideal for a household appliance like an air cooler. However, controlling the speed of an induction motor can be more challenging than with some other types of motors, but in an application like an air cooler, this isn't usually a problem.
Advantages and Disadvantages of an Induction Motor
Letโ€™s now discuss what are the specific advantages and disadvantages of Induction motor used in Air Coolers.
Advantages of Induction Motors in Air Coolers:
  1. Simplicity and Ruggedness: Induction motors are inherently simple because their design involves fewer moving parts compared to other motor types. For instance, they don't have brushes, commutators, or slip rings, components that are prone to wear and tear and require regular maintenance. The absence of these parts contributes to the motor's ruggedness, resulting in a longer lifespan and greater reliability. This robustness makes them well-suited to applications where the motor needs to run continuously for extended periods, like in air coolers.
  2. Cost: When compared to other types of motors delivering the same power rating, induction motors are generally cheaper. This cost-effectiveness comes from the simplicity of their design and the common materials used in their construction (usually iron and copper). As a result, they present an affordable option for manufacturers of devices like air coolers, which helps to keep the retail price of these appliances down.
  3. Efficiency: Induction motors have high efficiency, especially at full load. The efficiency of a motor is a measure of how well it converts electrical energy into mechanical energy. In the case of an induction motor, most of the electrical energy is effectively converted into rotational motion with minimal energy lost as heat. This characteristic makes induction motors a good choice for any energy-intensive application, including air coolers.
  4. Safety: Induction motors are safer compared to some other types of motors because there's no direct electrical connection to the moving parts. This separation greatly reduces the risk of electric shock. In addition, since the motor is completely enclosed, it's also protected from environmental factors, further enhancing safety.
Disadvantages of Induction Motors in Air Coolers:
  1. Speed Control: One of the limitations of induction motors is that their speed can't be easily controlled. The speed of an induction motor is primarily determined by the frequency of the AC power supply and the number of poles in the motor, neither of which is easy to change. Therefore, unlike DC motors, where speed control is relatively straightforward, varying the speed of an induction motor requires complex methods, such as varying the frequency of the power supply.
  2. Starting Torque: Starting torque refers to the rotational force produced by a motor when it begins to run from a stationary state. In general, induction motors have a lower starting torque compared to some other types of motors. However, in the case of an air cooler, high starting torque is not usually required, so this disadvantage doesn't significantly impact the application.
  3. Power Factor: The power factor of an induction motor is a measure of how effectively the motor converts electrical power into useful mechanical power. At full load, induction motors typically have a good power factor. However, when the load decreases, the power factor also drops, which can lead to inefficiencies. For an air cooler, which may not always operate at full load, this could result in a slight decrease in energy efficiency. However, in many cases, the impact is minimal and outweighed by the other advantages of induction motors.
In summary, the induction motor is a good choice for an air cooler due to its reliability, ruggedness, and cost-effectiveness.
However, some models of air coolers may use different types of motors like brushless DC motors for specific features such as speed control or energy efficiency.
I hope this answers your question. Let me know if you have more questions. I will be happy to answer them for you.
  • lal
    lal
    @lal-R60Xjx • May 7, 2013
    Induction motors are mostly used for this purpose. Silent operation and a rugged construction with low maintanence makes it ideal for a device designed to work in ac supply.
  • jyothirmaijo
    @jyothirmaijo-yvPmoh • May 8, 2013
    is there any specific type of induction motor????
  • lal
    lal
    @lal-R60Xjx • May 8, 2013
    Can you elaborate a bit about what you meant about the type of Induction motor?
    Single phase squirell cage induction motors will be enough to be used in general house hold coolers.
  • zaveri
    @zaveri-5TD6Sk • May 8, 2013
    Or on the other hand i think the capacitor start induction run motors are used.
  • jyothirmaijo
    thanku sir/mam....
  • zaveri
    @zaveri-5TD6Sk • May 9, 2013
    So are you doing some kind of a project or something on air-coolers ?
  • lal
    lal
    @lal-R60Xjx • May 9, 2013
    jyothirmaijothanku sir/mam....
    Oh! No sir or madam. We are all, including you, a bunch of Crazy Engineers ๐Ÿ˜
    Have fun bulding and innovating.
  • jyothirmaijo
    @jyothirmaijo-yvPmoh • May 17, 2013
    zaveriSo are you doing some kind of a project or something on air-coolers ?
    no no its the question which has been asked during our viva...... ๐Ÿ˜€
  • jyothirmaijo
    tha
    lalOh! No sir or madam. We are all, including you, a bunch of Crazy Engineers ๐Ÿ˜
    thanku... ๐Ÿ˜€
  • kunjgupta03
    @kunjgupta03-NiFA1r • Jun 15, 2015
    Can anyone tell me the specifications of motor used in revolving flap of air conditioner and small coolers.
  • vamsi kancharla
    @vamsi-kancharla-kL9oxU • Jun 21, 2015
    jyothirmaijosir/mam can u specify the type of motor which is used in air coolers......
    air cooler consists of two motors one is air blower motor it a an capacitor start run induction motor and the other motor is for circulating water around the grills this motor is a shaded pole induction motor .
  • jadeja sandipsinh
    @jadeja-m0Ydr6 • Sep 2, 2015
    can capacitor start induction run motor provide high torque at starting time?
  • vamsi kancharla
    @vamsi-kancharla-kL9oxU • Oct 1, 2015
    water cooler has two motors one for water circulation and other for air blowing
    air circulation motor---single phase capacitor start run induction motor (or)
    capacitir start induction motor is used
    the selection depends on the size and cooler design
    water circulation motor---shaded pole submersible induction motor
  • vamsi kancharla
    s u jadejacan capacitor start induction run motor provide high torque at starting time?
    that depends up on the rotor resistance if resistance of the designed rotor is high then the torque will ge high and viceversa.
  • mayur agarwal
    @mayur-20q8of • Mar 7, 2016
    vamsi kancharlathat depends up on the rotor resistance if resistance of the designed rotor is high then the torque will ge high and viceversa.
    vamsi kancharlaair cooler consists of two motors one is air blower motor it a an capacitor start run induction motor and the other motor is for circulating water around the grills this motor is a shaded pole induction motor .
