Two-wheelers with belt drives
zaveri
@zaveri-5TD6Sk โ€ข Oct 21, 2024
As we all know that motor cycles make use of chain drives as means of transmitting power from engine to rear wheel.
Now i was wondering what would happen if this chain-sprocket thing was to be replaced by belt and pulley system.
it will have its own advantages : it will be lighter, noise levels will be reduced, and it will make the vehicle designer's job easier.
Does it have any advantages though ? is this feasible ?
  • mechky
    @mechky-jbqpJD • Jul 22, 2012
    No, belts can't be used due to following reasons:
    - Belts have much less strength than chains
    - Susceptible to slip, speed ratio doesn't remains constant
    - Periodic retensioning is required
    - Upper limit on power and speed
    - Belts deteriorate on exposure to lubricants
    - Limited life and need periodic replacement
  • zaveri
    @zaveri-5TD6Sk • Jul 22, 2012
    mechkyNo, belts can't be used due to following reasons:
    can you elaborate on this ?
    @ramani-VR4O43 • Jul 22, 2012
    Belt drives depend on friction. Things may happen to reduce this at a critical moment leading to accidents. mechky's elaboration is explicit.
  • mechky
    @mechky-jbqpJD • Jul 24, 2012
    zaverican you elaborate on this ?
    speed limit is about 2000m/min and power limit is about 60kW
  • zm-i
    @zm-i-MjDXTb • Jul 26, 2012
    Some cars use timing belts. Some motorcycles also use belts. And there seems to be no problem.
    Please correct me if I am wrong. ๐Ÿ˜•
  • zaveri
    @zaveri-5TD6Sk • Jul 26, 2012
    zm-iSome cars use timing belts. Some motorcycles also use belts. And there seems to be no problem.
    Which are those bikes
  • zm-i
    @zm-i-MjDXTb • Jul 27, 2012
    Aren't those belts?๐Ÿ˜•
  • zaveri
    @zaveri-5TD6Sk • Jul 28, 2012
    zm-i
    Yes those are belts. those are ribbed belts. they are basically used for timing. they seem to make good substitutes for chain drives in those harley davidsons .
  • zm-i
    @zm-i-MjDXTb • Jul 28, 2012
    So belts can be used, right?
  • zaveri
    @zaveri-5TD6Sk • Jul 31, 2012
    zm-iSo belts can be used, right?
    ofcourse. as you can see that they are already being used.
  • zm-i
    @zm-i-MjDXTb • Jul 31, 2012
    Yes. I do recognize that #-Link-Snipped-#. ๐Ÿ˜€ However, the first respond to your topic is a "no". So, I wonder if what #-Link-Snipped-# says is true.
    I never really know the reason why, but I know that many have substituted chains with belts (...and of course they change the sprocket too).
  • zaveri
    zm-iYes. I do recognize that #-Link-Snipped-#. ๐Ÿ˜€ However, the first respond to your topic is a "no". So, I wonder if what #-Link-Snipped-# says is true.
    i first said no, because mechky gave strong reasons. But now since belt drives are implemented and the bikes are running normally, then there is no point in disagreeing
  • mechky
    @mechky-jbqpJD • Aug 1, 2012
    Yes, toothed belts similar to timing belts are appropriate.
