  • Saandeep Sreerambatla
    @saandeep-sreerambatla-hWHU1M • Jan 28, 2010
    Nothing will happen.
    There should be a closed loop for the current to pass! so if nothing is passing then there will be 0 current so i guess nothing happens.
    PS. Why do you want to do this?
  • Rifaa
    @rifaa-NaWZZ4 • Jan 29, 2010
    No current can pass through without a Potential difference.
    In some cases the two motor terminals can be positive to a given common ground, but the motor will operate only when the motor terminal voltage has a difference high enough to cause the motor to react. In this case the terminal voltage seen by the motor is +ve and -ve, even though they can be positive to another given ground reference
    Rifaa
  • imnitsy
    @imnitsy-VRNV82 • Jan 29, 2010
    I think the windings of motor will burn!!
    the current provided to the motor will be unable to find the proper path to leave, since both the potentials are positive therefore a less amount of current will flow out from the less positive potential thus results in improper rotation and it cause over heating of the windings!!
  • Rifaa
    imnitsyI think the windings of motor will burn!!
    IT WON'T !! Don't believe me.
    That's because you don't have any experience on that matter.
    Rifaa
    @saandeep-sreerambatla-hWHU1M • Jan 29, 2010
    It will not!
    There is no current which is passing so no buring nothing!
  • rasu3045
    @rasu3045-DKPodw • Jan 29, 2010
    Nothing will happen.Because two positive singal means no closed loop circuit(one positive and negative is closed loop)therefore no current passes through the winding.Dc motor still idle.
  • Rifaa
    Sheeesh ! guys.
    None of u have any experience on these type of matters, right.
    Motor will operate exactly stated in my reply.
    Rifaa
  • imnitsy
    RifaaSheeesh ! guys.
    Rifaa
    thats what i said!!
    the motor will work but very inefficeintly, and probably the winding will get burn due to over heating!!๐Ÿ˜‰
  • Rifaa
    imnitsythats what i said!!
    Ding! Ding! Ding!Ding!Ding!Ding!wrong!!!! ๐Ÿ˜
    Motor won't burn as long as the motor terminal voltage does not exceed it's rating.
    Motor will operate normally..
    Rifaa
    @saandeep-sreerambatla-hWHU1M • Jan 30, 2010
    I said it wont work!! but that's partially correct though!!
    I go with Rifaa , if there is potential difference the motor runs probably!!
    But can some one tell me how the circuit will become a closed loop?
    I have some confusion , practically assuming it I dont get the closed loop..
  • Rifaa
    @rifaa-NaWZZ4 • Jan 30, 2010
    Can u imagine a PSU with multiple out puts, say 12V , 5V with a common -ve.
    If you can, then tell me what is the difference between the two positive voltage?
    Rifaa
  • manoranjan
    @manoranjan-yHFByH • Jan 30, 2010
    i think the motor will run only if it will give some potential across the two terminal.if the two positive terminal can cause a closed loop through the motor armature then it can happen.but its quite difficult because the armature coils can burn with excss heat
  • sanks85
    @sanks85-20puY7 • Jan 30, 2010
    ๐Ÿ˜ya thats right if there is no closed loop than current will not find any returning path..but if the two terminals find +va and -ve wrt. reference (say ground) than motor can be operated...
  • piyushh
    @piyushh-O70sb6 • Jan 30, 2010
    ya.i agree wit rifa.........imnitsy i think u must fiirst better read the concepts of eletrostatics n current electricity., first it needs to give the minimum voltage to operate motor..on the other hand you are appling two positive voltage which finally reduces the net potential difference applied...
    so how come it will damage buddy, if that p.d is not more enough to drive the motor even...!!
  • piyushh
    i got my mistake, closed loop should be there..n for getting that we must have a single source or multiple source connected together..to form a closed loop
  • Rifaa
    at least some one have an idea on motor practical application.
    Newbies, if u are not sure then don't make judgments. learn from the experienced ones.
    That's why we are here.
    Rifaa
  • gourav anand
    @gourav-anand-E8ytSy • Jan 30, 2010
    i think it won't work
    because for functioning of dc machines there should be polarities of +ve n -ve s. if u are able to do so it w'ld be miracle, best of luck to you for your innovative idea
  • rasu3045
    @rasu3045-DKPodw • Jan 30, 2010
    Rifaa
    is it really run?.You confused me even though I have not tried this test
    It should be open circuit anyhow i need some clarification
  • piyushh
    rasu3045Rifaa
    i guess..it will not work and it will never form a closed loop..if there are two positive supply of different magnitude from different sources
    as ,the voltage source is a type of source in which energy is stored in the form of voltage so its output is voltage,,,and the power and energy are always in the form of force,,so voltage must be a force..and i guess for producing an emf on output terminals of the battery, internally there should be a closed path(high resistance)..i mean like in electrochemical cells.which pushes the electrons from negative termical..through output path(load) to transfer the energy(or say electrons) between electrodes of cell
    so i guess if we give positive suppy from two different sources of different magnitude..still it be open circuit
    @saandeep-sreerambatla-hWHU1M • Jan 31, 2010
    Thanks Rifaa!!
    I understood the concept behind it!!
  • Rifaa
    @rifaa-NaWZZ4 • Feb 1, 2010
    For those dummies out there. Read carefully ๐Ÿ˜‰
    First thing is to learn about dual supply capable PSU's, or even with triple out puts, or what ever that is.
    Supplies with more than one out put have different voltage levels, for example , take dual voltage one with a 12V and a 5 volt. They should have a common ground which makes it a common reference to the two +ve voltages. A DMM connected to to -ve and +12V will give +12V, now if u wish to measure the +ve 5V, u would just move the +ve meter lead. which is common sense. Now comes the tricky part, if the ground is not common to both rails, one +ve side will read zero, both rails will give a reading only if both +ve rails shares a common ground.
    Now if u were to put the meter at the both +5V and +12V, the meter will give a reading of +7V. Provided u connect the -ve terminal of the DMM to +5V and +ve terminal to +12V. If you reverse them you would get -7V.
    But the problem is this reading is only possible if the rails shares a common ground. If not meter reading will be zero, which gives you "YOUR" closed loop.
    Now if you were to connect a motor with a voltage rating close to +7V.
    What would happen.
    From here I will let your imagination run wild.
    Peace ๐Ÿ˜
    Rifaa
  • raghunathreddy36
    @raghunathreddy36-FhZFqH • Feb 1, 2010
    i can not understand you answers
  • Rifaa
    @rifaa-NaWZZ4 • Feb 2, 2010
    raghunathreddy36i can not understand you answers
    Then I donno what to say. Can't make it simpler than this
    Rifaa
