CrazyEngineers Archive
Old, but evergreen and popular discussions on CrazyEngineers, presented to you in read-only mode.
@Ronan • 28 Jun, 2011
Hi all,
I'm experiencing a difficulty understanding how the trapezoidal loads are distributed and how to shear moment diagrams are drawn for structural members subjected to trapezoidal loading.
For example below example is frame member subject to trapeze load, due to the fact that this memeber is extracted from 3D frame building it has initial shear and moment at ends resulted from fixed - end moments(equivalent nodal loads) loading.
So my hand-calculations is as below(x distance as variabel) and want to compare them with software calulated values.
Vshear = 150 - q*x2/(2*A);
Mmoment=150*x -q*x3/(2*3*A);
A = triangular horizontal leg-length of trapezoidal load. (A=100cm , span = 400cm; q=1kg/cm )
the above formulas produces the consistent results for boundary conditions and same with software results but in-between values are wrong.
For example if x = 30cm then Vshear = 145.5 kg where as software finds 142.5 kg.
Any comments will be appreciated.
Regards,
![[IMG]](proxy.php?image=http%3A%2F%2Fi55.tinypic.com%2F1zdcfop.jpg&hash=d2cef08211c864019af46a18ed2c6849)
Regards,
@Capt Spark • 01 Jul, 2011
no idea but are you sure that the SFD from the s/w is right? It should change from parabola to linear where the load becomes uniform from linear. It appears to me to be happening much before at the left end. It may be a graphics problem of the picture though.
5k views
@devi pujitha · May 20, 2012
What is the difference between timer and watchdog timer?
6.1k views
@thaiffer · Nov 26, 2009
I need to determine the maximum voltage swing for a Transistor circuit I have constructed. I have researched it in books and online but I'm struggling to understand it. The...
5k views
@Niharika_002 · Jul 15, 2015
I have got PWG( pass with grace) status on my 2nd sem result.I want to remove it can i give the exam once again in which i have got grace...
19.2k views
@Ankita Katdare · Jan 28, 2011
Domain: Data Mining
Heterogeneous Transfer Learning with Real-World Applications
Towards an Effective XML Keyword Search
Extracting Content Approach for Web Pages Based on Visual Representation
Effective Personalized Privacy Preservation
Sorting...
7.1k views
@Kaustubh Katdare · Jun 10, 2013
Sony literally won the E3 conference punching the hell out of Microsoft's XBOX ONE. The price of Playstation 4 in the US is $399 and it won't be wrong to...
8.7k views
