Transmission in a cycle rickshaw......
Iconoclast
@iconoclast-00ut5N Oct 26, 2024
In a manual cycle rickshaw, out of two rear wheels, only one is attached to the rear axle while the other one is kept free (it is free to rotate on the axle).
Why is it so?
  • raj87verma88
    @raj87verma88-ZpL2Wn Mar 25, 2010
    To help it during turning. While taking a turn the outer wheel moves at a greater speed as it covers more distance in the same time. If both wheels are attached to the axle then thy will have the same speed and it will be difficult to take a turn.
  • Vega
    @vega-Ic42ds Mar 26, 2010
    As told by Prateek, if both rare wheels are connected to power transmission directly, it will cause skidding while turning. To overcome that, one might have to use a differential. But diff will cause a transmission power loss due to introduction of more parts. Also in bycycle, it's not justifiable.
