Transistors which can be switched with Magnetism.
Abhishek Rawal
@abhishek-fg9tRh โ€ข Oct 21, 2024
Transistor, the main component of all modern devices,usually uses very low voltage change to toggle between "ON" & "OFF" state (to act as switch).
This approach of controlling voltage & using transistor as switch is very reliable but it has disadvantages too :
1) Sustaining the required voltage for required power drives the energy consumption.
2) Transistors are hard-wired into circuits & cannot be re-configured.
But this new invention of transistor which can be switched using magnetism suppose to solve this disadvantage (an other disadvantage might pop-up,but still haven't obtained) & will also allow chip to re-program.
Does this means transistors are re-programmable ??
Read more : #-Link-Snipped-#
&โ€‹#-Link-Snipped-#โ€‹ โ€‹Interesting ๐Ÿ‘โ€‹
