@netfreak-DHf76s • Nov 21, 2009
where can i even find an info about whats a stepup transformer, a step down transformer ?
how can it be made, or how can it be used in what ways :-s -
@manish-r2Hoep • Nov 21, 2009
netfreakwhere can i even find an info about whats a stepup transformer, a step down transformer ?
how can it be made, or how can it be used in what ways :-sUpto which i know
Step up transformer increase the voltage and step down transformer decreases the voltage
it depends on no of turns on coils
For further help use google -
@cooltwins-I5yJpZ • Nov 22, 2009
avinav_sanuIs there any tranformer designed which can work both as step up and step down?????
i am no big genius in this subject but this thought occurred to me ....
may be you can develop a transformer set up with fixed set of windings in the primary end and numerous no. of windings in the secondary side and use some arrangement (just like in a rheostat) to connect only a part of it (or how much ever necessary) to the external circuit so as to decide the nature of the transformer.
what i mean is that depending on the no. of turns you decide to include, its properties can be selected.
if you include more no. of windings in sec. when compared to No of turns in primary => you have got a step up transformer.
else=> you have got a step down transformer.
hope your doubt is cleared...๐ -
@just2rock-DkmPtO • Nov 23, 2009
Use a simple formulae for this....N1/N2=V2/V1
here N1 & N2 are the primary & secondary turns of the coils on the transformer respectively.V2 & V1 being the voltage output as req...derive your output voltage as required with this formulae .I believe you will get the step up or down based on that -
@civilprincess-308hDv • Nov 23, 2009
but the need is for a transformer that can act as both step up and step down and not for two transformers - one step up and one step down , right? so isn't what cooltwins said the appropriate one? this is just a thought....๐
@ramkumarj-ibyB7O • Jan 12, 2010
ya. Auto transformer which can be worked either step up or step down
@saandeep-sreerambatla-hWHU1M • Jan 12, 2010
cooltwinsif you include more no. of windings in sec. when compared to No of turns in primary => you have got a step up transformer.
hope your doubt is cleared...๐I think you have given opposite statement!
More no of turns in secondary will give a step down transformer and vice- versa.
There is a concept called Auto transformer which serves your purpose depending upon the requirement we can set it. -
@kapilbec-tmRzSe • Jan 13, 2010
I think its simple keep the number of primary turns constant and put 3 to 4 tappings on the secondary side for different number of turns .....if n2/n1 is more than 1 it is step up and vice versa
@sauravgoswami-UAfTlI • Jan 13, 2010
Well it is not possible to have step-up and step-down operation with same turns but with same transformer it is quite possible,you have to make separate tap connections,but why exactly we need such transformers, i am not getting it ?
@supri-cs-35NiDj • Jan 14, 2010
Yeah its possible by having a constant number of turns in the primary and having few tap changes in the secondary. This is the principle behind auto transformers. We can also find other tap changing transformers with this option these days.
@sankar3-zW2sfd • Feb 11, 2010
In my project we have a small ac voltage... can i increase it with the step up transformer..... if it possible send me the product details......
@sanks85-20puY7 • Feb 11, 2010
cooltwinsi am no big genius in this subject but this thought occurred to me ....
hope your doubt is cleared...๐ya even i think that this couls be the only way...
@sankar3-zW2sfd • Feb 12, 2010
is it possible to make our step up transformer?....
if possible..... what are the specifications to be taken and how can we make it?......plz reply me fast -
@thesis123-GQniZl • Feb 12, 2010
Yes, This can be achieved by using Auto transformer. Input voltage from supply is 230v/ 440v and the A.T output voltage is from zero to its rating. You can see the operation in your Electrical machines lab of any engineering college
i just have only 0.5-1v range...... is it possible to amplify it by using step up transformer? if possible is there any transformer product in market or we have to make it?
As I know, it is a small voltage and it can be step up up to certain levels like in radios or any small electronics gadgets. I don't know what is the level of voltage you want step up. Lot of material is available in the net, you can surf.
i want to amplify it(0.5-1v range) without any use of external voltage source............ is it possible?
@thesis123-GQniZl • Feb 13, 2010
You can find an useful information at this link
with best wishes, -
@070790vivek-09g1Yf • Feb 15, 2010
yes both operations step up and step down is not possible in one transformer
but u can make it by a simple arrangement
make 2 coils
in one coil no. of turns should > other one
now keep an arrangement like that when u want step up then the input current should supply to lesser no. of turns having coil and output should be from other
to find step down APPLY VICE VERSA๐
THIS arrangement can be control by a lever๐
i think my idea is so good to work on it ๐
if i was a electrical engg. then i would work on it.
u can change world with the power of your mind
@lal-R60Xjx • Feb 16, 2010
What if we just invert the terminals? I mean just by giving i/p to secondary and taking o/p from primary.
@sankar3-zW2sfd • Feb 20, 2010
lalWhat if we just invert the terminals? I mean just by giving i/p to secondary and taking o/p from primary.
yeah nice doubt..... i also have the same one...
