tranmitting a 10Mhz bandwidth message signal
abhirv
@abhirv-onWvxk โ€ข Oct 26, 2024
hello,
Can anyone please help me out in this problem related to communication.... how can i transmit a message signal (mostly sinusoidal..eg from signal generator) of freq ranging from 100hz to 1Mhz wirelessly over a short range(<10m) .which modulation technique should i use .analog or digital.its urgent please,.. i m stuck in my final year project here.
  • narayana murthy
    @narayana-z4W16q • Apr 16, 2011
    in my view analog is more better
  • Mr.Don
    @mrdon-92OwlG • Apr 16, 2011
    Use encoder with digital signal. I use it in my project.
    P.S: I don't know much about communication ๐Ÿ˜” but I used above for lower rating.
  • abhirv
    @abhirv-onWvxk • Apr 16, 2011
    thank u very much sir... i dint expect such a quick reply from anyone..i any forum....cant i go for a fsk modulation to transmit it...? and if analog, fm is better rite..? and are there any ic or module for message signal at this range..actualy im planning to display it wirelessly in osciloscope..
  • abhirv
    i dint get u... u mean i l ve to use some dsp to code the signals and transmit it...?I actualy wanted to send it to a dsp for further processing! my transmitter part should contain very less components like only adc(if digital modulation techniques r used) and a modulator circuit for transmitting not much....
  • Mr.Don
    This information might help you as this was the transmitter module used in my project.
    ASK Transmitter Module (ST-TX01-ASK (Saw Type)
    General Description:
    The ST-TX01-ASK is an ASK Hybrid transmitter module. ST-TX01-ASK are designed by the Saw Resonator, with an effective low cost, small size, and simple-to-use for designing.
    Frequency Range: 315 / 433.92 MHZ.
    Supply Voltage: 3~12V.
    Output Power: 4~16dBm.
    Circuit Shape: Saw.
  • abhirv
    thanks for that..... may i know what was the message signal bandwidth that u had used in ur project....?
  • abhirv
    sir...,are there any module or ic to transmit analog signals of around 10Mhz b/w (fm modulater ic) over short range..? i m transmiting this signal for further processing to dsp...
    @ramani-VR4O43 • Apr 19, 2011
    Here is an instrument that transmits measured data over wireless:
    [video]https://www.extech.com/instruments/resources/flash/flash.asp?title=EX540%2FEX542+Showcase+Video&filename=ex540showcase.swf&width=640&height=360[/video]
    Extech Instruments Corp. - Cat IV Wireless Multimeter & Datalogger
    Bioramani
  • abhirv
    @abhirv-onWvxk • Apr 20, 2011
    Thank u sir.... for the info about the wireless dataloggers.. got some ideas to improve my project..!
    abhirv
