@ninad-joKnnV • Oct 2, 2006
Re: Multiple login problem
Hi ,
I would like to know what kind of Wifi network you are connecting to.
Does your network have DHCP or you are alloted static IPs ( per user basis)?
It is possible to trace the IP till the Wireless Access Point you are connected to.It means the access point can keep the track of IPs connected to it. And geographically one can broadly identify the area covered by any specific Access Point. -
@hellmate-OwOMAw • Oct 3, 2006
What is the IP of the far end computer.
Hey...π
Thanx Ninad,
To all the CEans and their good friends...
Now...
Is it possible to know while chatting to someone that what is the static IP of his computer?
If yes, Pleaze list some methods... -
@thebigk • Oct 3, 2006
Re: What is the IP of the far end computer.
hellmateHey...π
Thanx Ninad,
Now...
If yes, Pleaze list some methods...Hellmate, are you trying to crack someone's computer? We'd not allow discussions on cracking and illegal hacking.
Anything illegal is banned on CrazyEngineers π . Of course, obtaining IP address shouldn't be a big deal.
-The Big K- -
@rahul-yHGH3D • Oct 4, 2006
Hi,
Generally it is possible to track even the physical location of the person to whom you are chatting to .
You have to just send him a file over messenger. Once he accept the file and start downloading it , you have to run the command "netstat -n". Here you can find the "ESTABLISED" connection which will show the IP adress of the another person.
You can provide the IP address and can trace the physical location of the person usng the site #-Link-Snipped-#.
Rahul -
@xheavenlyx-CbvN62 • Oct 6, 2006
Just as a side note. Hacking doesnt need to be illegal if we use it just to learn. Not destroy someones life or PC. π
"You can only learn something after you break it and put it back together!" (Ofcourse, not someone elses!) π
Thats my rule in elecrtonics and computers. -
@thebigk • Oct 6, 2006
Well, there's a rule. In a play, if you show a gun hung on the wall - some actor will use it for sure. π (making sense?)
Of course there is a difference between hacking & cracking. Hacking is good and cracking is not! Of course, discussions on hacking are allowed as long as the discussion doesn't generate evil ideas. π²
-The Big K-
@ud-U9lziD • Aug 23, 2009
Hi Hellmate,
Precaution is better than cure.... this is what i believe in
There is no bad in being an Hacker who knows how a cracker works, i wont be telling you any ideas of being a hacker but you can protect your wireless network by applying security on it.
For more information regarding Wi-Fi security please check
www(dot)host.co.in/forums/f20/war-driving-849/
Note - Please replace the "dot" with an actual "."
Regards,
Sudarshan
One for All... All for One
