!!Total security solution!!READ it througly.
ashutoshglamour
@ashutoshglamour-YcpJXd • Oct 17, 2024
TOTAL SECURITY
SOLUTIONS
1.RX101 CRYSTAL-CONTROLLED RECEIVER
PORTABLE SIGNAL REPEATER
AR3000A PROFESSIONAL MONITOR RECEIVER
AR8000 HAND-HELD SCANNING RECEIVER
MICROPHONE AUDIO SURVEILLANCE SYSTEM
WALL AMPLIFIER SURVEILLANCE SYSTEM
MCX-06 SIX CHANNEL MAINS CARRIER AUDIO SURVEILLANCE SYSTEM
LOW-COST SURVEILLANCE TAPE RECORDER
L400 MICROCASSETTE RECORDER
SONY TR6 6-HOUR SURVEILLANCE TAPE RECORDER
TELERHONE HANDSET RECORDER
E1000 DIGITAL TELEPHONE & FAX MONITORING SYSTEM
GPS-BASED VEHICLE TRACKING SYSTEM
SDMS SURVEILLANCE EQUIPMENT
REF: SU195
The RX101 is a crystal-controlled receiver which has been
designed for use with our covert transmitters.
The RX101 Receiver provides
extremely high quality sound
definition, and can be supplied in any
VHF or UHF frequency. It comes
complete with a headset and
connector cable for use with a voiceactivated,
reduced-speed tape
recorder for unattended use. The
RX101 Receiver’s small size and
light weight make it ideal for covert
use. It can be supplied either in a
single channel or a two-channel
version.
Size: 56 x 115 x 20 mm
Weight: 210 g
Power Supply: 9V
2.PORTABLE SIGNAL REPEATER
REF: SU193
The Portable Signal Repeater has been designed specifically
for use with our covert transmitters. It receives the signal from
a nearby transmitter and ’boosts’ the signal range with a
selectable power output of between 1 and 5 watts. Depending
on the output power chosen, the signal can be ‘boosted’ over a
range of many miles.
The equipment is extremely ruggedly constructed and its small
size and signal antenna enables it to be covertly positioned for
unattended use outside a ‘target’ location. The Portable Signal
Repeater receives the signal on the same frequency as the
transmitter and then repeats it over a different frequency to a
receiving station. A separate receiver for the ’boosted’ repeater
signal is required.
Size: 2l8mm x 118mm x 79mm
Frequency range: VHF or UHF
Power output: 1 to 5 watts selectable
Supply voltage: 12V
Weight: 2 kg
Separation: +/- 5 MHZ
Connectors: BNC
3.AR3000A PROFESSIONAL MONITOR RECEIVER
REF: SU175
The AR3000A is a top-quality scanning receiver used by many
security professionals to monitor covert transmitters, thus
eliminating the need for a dedicated receiver for each
transmitter.
The AR3000A offers the widest
frequency coverage on the market
today, with an extremely high level
of performance and versatility
through shortwave, VHF and
onward to the upper limit of UHF
and SHF. As of January 1997, over
70,000 units have been sold
worldwide.
The AR3000A Receiver will allow listening on any mode: NFM,
WFM, AM, USB, LSB and CW. Tuning rates are selectable from
ultra-fine 50Hz steps for SSB and CW right the way up to 999.95
Hz for the TV and VHF broadcast bands.
Size: 138 x 80 x 200 mm
Weight: 1.2 Kg
Frequency Range: 100 KHz - 2036 MHz
Memory Channels: 400
Scan Rate: 50 channels / second
4.AR8000 HAND-HELD SCANNING RECEIVER
REF: SU204
The AR8000 is a highly sensitive hand-held scanning receiver
covering a wide frequency band from 500KHz to 1900MHz It is
ideal for portable audio surveillance applications, negating the
requirement for a receiver with a dedicated frequency.
At first glance the AR8000 may look no
different from any modern hand-held scanning
receiver, but the similarity ends there. The
high visibility LCD is of a new dot matrix
format which enables many new facilities to
be used, many of which have never been
seen before on a hand- held design.
The AR8000 is equipped with almost every
conceivable operating feature but operation
remains easy thanks to a massive new
microprocessor.
Size: 152 x 69 x 40 mm
Weight: 350 g
5.MICROPHONE AUDIO SURVEILLANCE SYSTEM
REF: SU233
* 10 Microphone channels available
* Telephone Interface option
* Cable link can be up to 1 mile
* Excellent audio quality
* Uninteruptible power supply
* Simultaneous recording of up to 11 channels
The hard-wired Microphone
Audio Surveillance System is
widely regarded as being one
of the most secure methods of
audio monitoring, as detection
of microphones by most
electronic countermeasures
difficult.
The system can accommodate up to 10 separate audio channels
and one telephone interface. It’s high specification, ultra-miniature
microphone/pre-amplifier modules are linked to the audio amplifier
and cabling can be as long as 1 mile.
6.WALL AMPLIFIER SURVEILLANCE SYSTEM
REF: SU144
This system has been designed for Police and other
professional surveillance operators for audio monitoring
through walls, floors and ceilings. Performance is excellent,
with clear audio pick-up through over 40cms (16") of a typical
solid wall structure.
The Wall Amplifier System comes as
a kit complete with high-sensitivity
accelerometer, probe microphone,
minature microphone, power supply
and high-gain amplifier contained in its
own case. The system can be
monitored with either the headset
provided or recorded on a voiceactivated,
reduced-speed tape
recorder.
The accelerometer element is a high performance, low impedance
unit designed for very low frequency vibration monitoring. The probe
microphone includes four inter-changeable probe lengths and the
miniature microphone is contained in a rugged nylon block for
maximum flexibility on installation.
7.MCX-06 SIX CHANNEL MAINS CARRIER AUDIO
SURVEILLANCE SYSTEM
REF: SU157
The MCX-06 Mains Carrier System is a low frequency mains
transmitter that uses standard AC electricity power cables as a
transmission path and as a source of power. An audio
compressor ensures good capture of all sounds within a room.
Transmitting time is indefinite since power is derived from the
mains power cables to which the unit is attached. The system
is supplied with a 2-wire active microphone assembly which
may be extended if desired. The microphone input stage is
compatible with both 2 and 3 wire active microphones and
medium impedance passive types.
The MCR-06 Six Channel
Receiver has been designed to
complement the MCX-06 Mains
Carrier Transmitter. The system
is supplied with one MCX- 06
Transmitter as standard, but up to
six transmitters can be used with
the MCR-06 Receiver.
MCX-06
Size: 33 x 67 x 21 mm
MCR-06
Size: 190 x 140 x 50mm
8.LOW-COST SURVEILLANCE TAPE RECORDER
REF: SU150
This low-cost, voice-activated mini-cassette tape recorder can
be selected to operate at half its normal speed without any
distortion in sound quality.
The high quality, precision-crafted recorder is
ideal for surveillance applications where it
can be left unattended to monitor audio
signals received from a transmitter, amplifier
or telephone.
Size: 123 x 55 x 22mm
Weight: 205 g
9.L400 MICROCASSETTE RECORDER
REF: SU192
The ultra-compact, L400 is the smallest microcassette recorder
currently in production, and is ideal for covert surveillance
operations. The recorder comes with a microphone with clipconnector
which makes it particularly useful for body-worn
applications.
* Separate microphone on cable with
clip-connector for body-worn applications
* Variable control voice-activation
* Dual speed-2 hour maximum recording
* Remote connector plug
Size: 73 x 52 x 20 mm
Weight: 90 g
10.SONY TR6 6-HOUR SURVEILLANCE TAPE
RECORDER
REF: SU151
The Sony TR6 6-hour voice-activated mini-cassette recorder
has been specifically modified for use in surveillance
operations where it can be left unattended within a building or
vehicle for long-time surveillance use.
The Sony TR6 6-Hour Recorder
contains a variable-gain, voiceactivated
facility which automatically
starts the recorder as soon as a signal
is received from either voice,
microphone or telephone intertace,
and then stops when the signal
ceases.
Size: 130 x 91 x 33mm
Weight: 300gm
11.TELERHONE HANDSET RECORDER
REF: SU237
The Telephone Handset Recorder contains an in-built recorder
which provides crystal-clear recording capability. It can be
connected in seconds by simply disconnecting the telephone
cable from a standard telephone and plugging it into the
Tetephone Handset Recorder.
The equipment is ideal for use in the office or at home when the
necessity to be able to instantly record telephone conversations
may be required.
* Replaces existing handset
* Plays back while on or off-line
* Connects in seconds
* 2 speed recording
* Variable speed playback
* Up to 3 hours of recording with MC-90 cassette
* Compact and lightweight
* One year warranty
12.E1000 DIGITAL TELEPHONE & FAX MONITORING
SYSTEM
REF: SU209
For very good reasons the new E1000 Digital Telephone and
Fax Monitoring System is the recognised leader in its field and
represents the most flexible and cost-effective system
currently available.
All calls - either telephone or fax - are recorded simultaneously in
three separate places – on a hard disc and on two Digital Audio
(DAT) tapes. The dual DAT drives are made with a reassuring mean
time between failures (MTBF) or 200,000 hours and even if a backup
tape is damaged or faulty, the data is fully protected.
The E1000 is remarkably simple to
install and use. With the choice of
analogue or digital interfaces, one
digital cable will link it to the telephone
system. The E1000 can record a
combination of up to 48 telephone and
fax channels simultaneously, with the
hard disc providing 275 voice hours of
recording and the two back-up tapes
can record an additional 550 voice
hours each. Smaller systems which
monitor 8, 16, 24, 32 and 40 telephone/
fax lines are also available.
13.GPS-BASED VEHICLE TRACKING SYSTEM
REF: SU236
The new GPS-Based Vehicle Tracking System uses the most upto-
date satellite navigation technology and high definition digital
mapping software to provide constant information on the location
of a “target” vehicle without visual contact.
The Tracking System consists of a specially-developed micro Global
Positioning Satellite (GPS) receiver which is the size of a matchbox, a
GSM cellular interface, power supply unit and a lap-top computer
incorporating a digitised colour mapping
system of the local area or country. A
number of vehicles can be tracked at the
same time and, depending on the
sophistication required, much information
regarding the status of the vehicleincluding
the vehicle’s location, speed
and fuel level - can be relayed back to the
receiving station.
The system is based on a well- proven
Automatic Vehicle Location system. This
system also makes use of signals from
GPS navigation satellites, and is currently
in use with UK and overseas government
agencies, as well as fleet operators, to
identify the exact location of their
vehicles.
Each Tracking System is tailored to meet the precise requirements of
a client and takes advantage of the latest advances in satellite
navigation, radio communications, as well as computerised digital
mapping technology.
The same technology can be used to track high value articles as well as
individual personnel. When incorporating an emergency button, the
system is also used for the protection of prominent VIPs, or other
personnel, who could be vulnerable to attack.
these systems give you total security solutions.
