  • omprakash patil
    @omprakash-Um9Ko0 • Jun 23, 2015
    what power source ur using?? motor h.p.??
  • PRADIP CHAKRABORTY
    @pradip-MzE4HZ • Jun 23, 2015
    nooneperfectwhat power source ur using?? motor h.p.??
    0.5 HP MOTOR
  • omprakash patil
    @omprakash-Um9Ko0 • Jun 24, 2015
    I'm trying but my calculations somewhere getting wrong.... u can use T/J=G thita/L formula for calculation of shaft twisting moment. For mild steel G is around 78 to 80 Gpa (what i have searched on net) , assuming thita= 1 degree.
    We can calculate torque required but somewhere im getting wrong answer and dnt know why .... but u can assume above data and can take some experts opinion.
    Maximum torque produced by 0.5 hp motor at 10 rpm is 356.0377 N-m.
  • Selvakumar Aruchamy
    @selvakumar-p6K2US • Jun 27, 2015
    nooneperfectI'm trying but my calculations somewhere getting wrong.... u can use T/J=G thita/L formula for calculation of shaft twisting moment. For mild steel G is around 78 to 80 Gpa (what i have searched on net) , assuming thita= 1 degree.
    Have you use tis formula??? Power = 2*pi*Speed*Torque/60, Nm
  • omprakash patil
    @omprakash-Um9Ko0 • Jun 27, 2015
    SelvakumarchelluHave you use tis formula??? Power = 2*pi*Speed*Torque/60, Nm
    Yes And the answer i alreday mention 356.0377 N-m.
    i guess thats Maximum torque for what motor produce at selective r.p.m. without any load applied,but for dia.250 mm ,10 mm thick actual torque will be different
  • Suraj Raju
    @suraj-raju-mDyby5 • Jul 2, 2015
    max torque=356.0377 Nm
    Design Torque=Max torque*k*k(not).
    assuming k*k(not) to be 1.25, Designed Torque=445.047125 Nm
  • Suraj Raju
    I 'm not sure of those k,k(not) values. If I 'm wrong, please suggest me a correct answer anyone.
