    @ramani-VR4O43 • Apr 7, 2011
    aicbalwhat is tonnage of AC machine? What is the diffrence between 1.5T capcity and 1.5TR capacity of a AC machine? Ton or Tonn ?#-Link-Snipped-#
    Before the days of AC machines, rooms used to be cooled by keeping blocks of ice usually at a height. The latent heat of melting of ice is 80 Kcal/Kg. It was found convenient to specify the cooling capacity of AC systems by the eqivalent latent heat of melting of ice. A 1.5 tonne AC poduces a cooling of 1.5 x 8000 Kcals in 24 hours. Ton in India is the Tonne (1000 KG)
    1 Tonne = 1000 KG
    1 Ton = 2000 Lbs
    Bioramani
  • aicbal
    @aicbal-t5T7aK • Apr 7, 2011
    what is 'TR'?
    @ramani-VR4O43 • Apr 8, 2011
    Tonnage Rating. Loosely used as tonnage alone. In India both seem to mean the same.
    Bioramani
  • shubhankar
    @shubhankar-CeulhT • Apr 9, 2011
    i had worked on a project at batukbhai jewellers electrical installation in nagpur. there we had a 22TR AC unit to cool the ground floor. moreover we had 3 separate 18 HP compressors for the other 3 floors. if i am not mistaken 1.5*HP rating is the TR rating
  • aicbal
    @aicbal-t5T7aK • Apr 10, 2011
    hi shubhankar, i think you are right. by the way, any one can say,
    1 T = how much kW?
  • shubhankar
    @shubhankar-CeulhT • Apr 11, 2011
    the HP in the above equation has to be converted to kW by multipliying by 0.746...thus we can easily establish the asked relation also/
