to test 555timer ic
shaibin k r
shaibin k r
@shaibin-k-r-dNk09B Oct 21, 2024
hi guys'
can we test a 555 timer ic using cro,probes and function generator?
if so ,how?
  • shreyasm89
    shreyasm89
    @shreyasm89-jGobVm Oct 22, 2010
    Ofcourse you can....since testing a timer will only involve testing the time period of the square wave signal, whatever values of R & C you'll use will decide the period of the ON & OFF pulse. T=R*C is the formula. Also 555 timer has 50% duty cycle so the square wave will be symmetrical. The o/p oin of the Ic has to be connected to the CRO using probes, and you should be able to view the square wave.You can use a standard 1khz signal as i/p.
