This is a simple Batch example on some of the colors you can change the txt to in dos
@lovekiller-oY5Tlk
1.0K
@ECHO OFF
color %num%
:start
cls
COLOR %num%
ECHO Green = 1
ECHO Red = 2
ECHO Yellow = 3
ECHO Aqua = 4
ECHO Purple = 5
ECHO White = 6
ECHO Blue = 7
ECHO Gray = 8
ECHO.
SET/P color=Enter Color:
IF "%color%" equ "1" goto 1
IF "%color%" equ "2" goto 2
IF "%color%" equ "3" goto 3
IF "%color%" equ "4" goto 4
IF "%color%" equ "5" goto 5
IF "%color%" equ "6" goto 6
IF "%color%" equ "7" goto 7
IF "%color%" equ "8" goto 8
IF "%color%" equ "exit" goto end
IF "%color%" equ "%color%" goto error
:1
set num=a
goto start
:2
set num=c
goto start
:3
set num=e
goto start
:4
set num=B
goto start
:5
set num=D
goto start
:6
set num=F
goto start
:7
set num=9
goto start
:8
set num=8
goto start
:error
cls
color 0
ECHO That is not a Valid Color
echo.
pause
goto start
just save this code in notepad and give name as filename.bat
__________________
color %num%
:start
cls
COLOR %num%
ECHO Green = 1
ECHO Red = 2
ECHO Yellow = 3
ECHO Aqua = 4
ECHO Purple = 5
ECHO White = 6
ECHO Blue = 7
ECHO Gray = 8
ECHO.
:1
set num=a
goto start
:2
set num=c
goto start
:3
set num=e
goto start
:4
set num=B
goto start
:5
set num=D
goto start
:6
set num=F
goto start
:7
set num=9
goto start
:8
set num=8
goto start
:error
cls
color 0
echo.
pause
goto start
__________________
