thirty five LM358 connect in parallel
Any have try before use an LM358 as a voltage follower/unity gain opamp to drive a 10ohm load? it is not working right? However, it seem that it will works if connected thirty five LM358 in parallel driving the 10ohm load, the output voltage can be adjust from the range of 0 to 10v. Any have done this experiment before kindly leave a comment or feedback because it is working but i have no idea will such connection spoil the IC or not.
