The single phase induction motor
then,
1) does this increase the torque of the motor as well.
2) if 3 or more capacitors of the same rating are connected in parallel, then will this damage the motor ?
@grsalvi-7IhIh1 • Nov 23, 2012
Zaveri we already discussed in a post, i believe same is true for your question asked now.See this post :zaveriIf a capacitor of equal microfarads is connected in parallel with the existing capacitor of a single phase induction motor, then the speed increases drastically.
then,
@zaveri-5TD6Sk • Nov 23, 2012
grsalvi1.The increase or decrease in torque depends upon the shift which your capacitor introduces.
zaveriWhat is "shift" ? can you elaborate ?
@naveee-QD5zHH • Nov 23, 2012
@grsalvi-7IhIh1 • Nov 24, 2012
Winding are capable of producing rotating magnetic field in case of 3 phase induction motor.naveeecapacitor is only used to increase the torque........rotation magnetic field is produced by the magnetic windings...... the how capacitor is used to convert stationary magnetic field into rotating one .??? #-Link-Snipped-#
@jeffrey-xA7lUP • Nov 26, 2012
Current associated with the conductor is what generates the magnetic fluxnaveeecapacitor is only used to increase the torque........rotation magnetic field is produced by the magnetic windings...... the how capacitor is used to convert stationary magnetic field into rotating one .??? #-Link-Snipped-#
