The programming language that earns you the most money
So I was wondering why <a href="https://www.crazyengineers.com/threads/what-is-the-reason-c-and-c-continue-to-be-relevant.77300">What is the reason C and C++ continue to be relevant?</a> continue to be very relevant in the modern world. I found the reason that not only C and C++ are "THE" languages to master; but they will earn you the most money in your career as a programmer! Found the answer while reading few discussions on Quora. So to summarise:-
- JVM was coded in ANSI C
- Linux is all C + Assembly
- Python's base is C
- OSX -> again C
- Windows OS: C & C++
- Oracle DB: C / C++
- Cisco routers: C
Basically, everything that's established the modern world of computing has the base in C or C++. So, if you can master C and C++ as your base in programming; you should be able to make a LOT of money as a programmer. Because you'll find it easier to master new languages and tools.
Do you agree?
