the differential
zaveri
@zaveri-5TD6Sk โ€ข Oct 17, 2024
the differential as most of us know is a device on the rear axle of a car.
it varies the speed of the wheels on the same axle during turning for reducing tire wear, a smooth turning etc etc.
it is a complex , yet an interesting mechanism.
what i am interested in knowing is , are there any other machines , apart from autos which make use of the differential
  • Siddhant Mukherjee
    @siddhant-4mGRnx • Mar 24, 2012
    the differentials are also used in mills with multiple axes you can easily control torque by varying speed of each axes using differential. They are also used in machine guns for fire control.
  • zaveri
    @zaveri-5TD6Sk • Mar 27, 2012
    S.mukherjeethe differentials are also used in mills with multiple axes you can easily control torque by varying speed of each axes using differential. They are also used in machine guns for fire control.
    you mean the milling machines ?
    and in what way do machine guns make use of it ? i would be curious to know
