Techincal Interview Questions - C Launguage
General Technical C Questions :
  • · What does static variable mean?
  • · What is a pointer?
  • · What is a structure?
  • · What are the differences between structures and arrays?
  • · In header files whether functions are declared or defined?
  • · What are the differences between malloc() and calloc()?
  • · What are macros? what are its advantages and disadvantages?
  • · Difference between pass by reference and pass by value?
  • · What is static identifier?
  • · Where are the auto variables stored?
  • · Where does global, static, local, register variables, free memory and C Program instructions get stored?
  • · Difference between arrays and linked list?
  • · What are enumerations?
  • · Describe about storage allocation and scope of global, extern, static, local and register variables?
  • · What are register variables? What are the advantage of using register variables?
  • · What is the use of typedef?
  • · Can we specify variable field width in a scanf() format string? If possible how?
  • · Out of fgets() and gets() which function is safe to use and why?
  • · Difference between strdup and strcpy?
  • · What is recursion?
  • · Differentiate between a for loop and a while loop? What are it uses?
  • · What are the different storage classes in C?
  • · Write down the equivalent pointer expression for referring the same element a[j][k][l]?
    [*]· What is difference between Structure and Unions?
    [*]· What the advantages of using Unions?
    [*]· What are the advantages of using pointers in a program?
    [*]· What is the difference between Strings and Arrays?
    [*]· In a header file whether functions are declared or defined?
    [*]· What is a far pointer? where we use it?
    [*]· How will you declare an array of three function pointers where each function receives two ints and returns a float?
    [*]· what is a NULL Pointer? Whether it is same as an uninitialized pointer?
    [*]· What is a NULL Macro? What is the difference between a NULL Pointer and a NULL Macro?
    [*]· What does the error 'Null Pointer Assignment' mean and what causes this error?
    [*]· What is near, far and huge pointers? How many bytes are occupied by them?
    [*]· How would you obtain segment and offset addresses from a far address of a memory location?
    [*]· Are the expressions arr and &arr same for an array of integers?
    [*]· Does mentioning the array name gives the base address in all the contexts?
    [*]· Explain one method to process an entire string as one unit?
    [*]· What is the similarity between a Structure, Union and enumeration?
    [*]· Can a Structure contain a Pointer to itself?
    [*]· How can we check whether the contents of two structure variables are same or not?
    [*]· How are Structure passing and returning implemented by the complier?
    [*]· How can we read/write Structures from/to data files?
    [*]· What is the difference between an enumeration and a set of pre-processor # defines?
    [*]· what do the 'c' and 'v' in argc and argv stand for?
    [*]· Are the variables argc and argv are local to main?
    [*]· What is the maximum combined length of command line arguments including the space between adjacent arguments?
    [*]· If we want that any wildcard characters in the command line arguments should be appropriately expanded, are we required to make any special provision? If yes, which?
    [*]· Does there exist any way to make the command line arguments available to other functions without passing them as arguments to the function?
    [*]· What are bit fields? What is the use of bit fields in a Structure declaration?
    [*]· To which numbering system can the binary number 1101100100111100 be easily converted to?
    [*]· Which bit wise operator is suitable for checking whether a particular bit is on or off?
    [*]· Which bit wise operator is suitable for turning off a particular bit in a number?
    [*]· Which bit wise operator is suitable for putting on a particular bit in a number?
    [*]· which one is equivalent to multiplying by 2:Left shifting a number by 1 or Left shifting an unsigned int or char by 1?
    [*]· Write a program to compare two strings without using the strcmp() function.
    [*]· Write a program to concatenate two strings.
    [*]· Write a program to interchange 2 variables without using the third one.
    [*]· Write programs for String Reversal & Palindrome check
    [*]· Write a program to find the Factorial of a number
    [*]· Write a program to generate the Fibinocci Series
    [*]· Write a program which employs Recursion
    [*]· Write a program which uses Command Line Arguments
    [*]· Write a program which uses functions like strcmp(), strcpy()? etc
    [*]· What are the advantages of using typedef in a program?
    [*]· How would you dynamically allocate a one-dimensional and two-dimensional array of integers?
    [*]· How can you increase the size of a dynamically allocated array?
    [*]· How can you increase the size of a statically allocated array?
    [*]· When reallocating memory if any other pointers point into the same piece of memory do you have to readjust these other pointers or do they get readjusted automatically?
    [*]· Which function should be used to free the memory allocated by calloc()?
    [*]· How much maximum can you allocate in a single call to malloc()?
    [*]· Can you dynamically allocate arrays in expanded memory?
    [*]· What is object file? How can you access object file?
    [*]· Which header file should you include if you are to develop a function which can accept variable number of arguments?
    [*]· Can you write a function similar to printf()?
    [*]· How can a called function determine the number of arguments that have been passed to it?
    [*]· Can there be at least some solution to determine the number of arguments passed to a variable argument list function?
    [*]· How do you declare the following : "An array of three pointers to chars", "An array of three char pointers" , "A pointer to array of three chars", "A pointer to function which receives an int pointer and returns a float pointer" , "A pointer to a function which receives nothing and returns nothing".
    [*]· What do the functions atoi(), itoa() and gcvt() do?
    [*]· Does there exist any other function which can be used to convert an integer or a float to a string?
    [*]· How would you use qsort() function to sort an array of structures?
    [*]· How would you use qsort() function to sort the name stored in an array of pointers to string?
    [*]· How would you use bsearch() function to search a name stored in array of pointers to string?
    [*]· How would you use the functions sin(), pow(), sqrt()?
    [*]· How would you use the functions memcpy(), memset(), memmove()?
    [*]· How would you use the functions fseek(), freed(), fwrite() and ftell()?
    [*]· How would you obtain the current time and difference between two times?
    [*]· How would you use the functions randomize() and random()?
    [*]· How would you implement a substr() function that extracts a sub string from a given string?
    [*]· What is the difference between the functions rand(), random(), srand() and randomize()?
    [*]· What is the difference between the functions memmove() and memcpy()?
    [*]· How do you print a string on the printer?
    [*]· Can you use the function fprintf() to display the output on the screen?
