  • TCS Latest Campus Placement Papers 2011 (New Pattern) With Solutions
    @abrakadabra
    Updated: Oct 26, 2024
    Views: 1.5K
    As you all know TCS has changed the test taking pattern since last year.
    The New TCS test has:
    1. No of questions: 35
    2. Test Duration: 80 Minutes
    3. Type: Logical Reasoning.
    I will attach a file of the latest questions here soon and we can discuss the solutions here.
    AdministratorAug 29, 2011
    Here is the final questions list.
    All the questions can be discussed here for solutions.
  • gs131016
    MemberAug 29, 2011
    thanks. please provide infosys,accenture and wipro latest pattern with solutions.
  • PraveenKumar Purushothaman
    MemberAug 29, 2011
    Isn't it solved? Where are the solutions? Can we discuss the answers in some thread?
    @AKD: Once this is solved, I am planning to host it in my Quiz Engine. What say?
  • CIVILPRINCESS
    MemberAug 29, 2011
    thanks akd 😀
    we've got TCS placement next monday 😀 i don't have the aptitude test so my friends will be able to use them 😀
    @CP: The doc file only has questions. We need to discuss the solutions here. Can you give it a head start?
    I have more questions to share.
    PS: Some answers can be found elsewhere on the net, but the answers are different everywhere, so we need to find full-proof solutions here.
  • CIVILPRINCESS
    MemberAug 29, 2011
    i've solved some of those already. can we discuss them here itself? 😀
    Yeah, Please. Share the solutions here.
    PS: It's highly likely that the same questions with different values will appear in the test.
  • CIVILPRINCESS
    MemberAug 29, 2011
    Given 3 lines in the plane such that the points of intersection form a triangle with
    sides of length 20, 20 and 30, the number of points equidistant from all the 3
    lines is
    • 4
    • 1
    • 0
    • 3
    solution:
    answer is 1. and that point is called incentre.
    explanation:
    now take a triangle and inscribe a circle inside the triangle. the circle must touch all the sides of the triangle as shown in the figure.
    inradius(big)
    the radius of the circle will equidistant from all sides since the circle touches all three sides. there exists only one such point... 😀
    P.S: click the image for a larger size 😀
  • CIVILPRINCESS
    MemberAug 29, 2011
    After the typist writes 12 letters and addresses 12 envelopes, she inserts the
    letters randomly into the envelopes (1 letter per envelope). What is the probability
    that exactly 1 letter is inserted in an improper envelope?
    • 11/12
    • 1/12
    • 0
    • 12/212
    answer: 0
    explanation:
    if one letter is inside a wrong envelope then there should be another one too which is in the wrong envelope. so the event of one error is impossible. so probability is 0.
    @CP: A lot of people say the answer is 4, where 1 in-centre and 3 exi-centers are considered. (I have no idea about this 😐 )
  • CIVILPRINCESS
    MemberAug 29, 2011
    There are two water tanks A and B, A is much smaller than B. While water fills at
    the rate of one litre every hour in A, it gets filled up like 10, 20, 40, 80, 160 .. in
    tank B. (At the end of first hour, B has 10 litres, second hour it has 20, and so
    on). If 1/32 of B's volume is filled after 3 hours, what is the total duration required
    to fill it completely?
    • 10 hours
    • 8 hours
    • 7 hours
    • 9 hours
    answer:
    explanation:
    1/32 filled in 3 hours.
    in the next hour it will double the content in it...
    i.e. 1/16 in in 4 hours
    1/8 in in 5 hours
    1/4 in in 6 hours
    1/2 in in 7 hours
    full in 8 hours
  • CIVILPRINCESS
    MemberAug 29, 2011
    AbraKaDabra
    check out this link: <a href="https://gogeometry.com/geometry/incenter_excenter_incircle_excircle.htm" target="_blank" rel="nofollow noopener noreferrer">TracenPoche Dynamic Geometry: Triangle: Incenter, Incircle, Excenter, Excircle, internal and external bisectors. College Geometry, SAT Prep. Elearning</a>ere three epicentres and incentre are drawn. the question asks for the point which is at the same time equidistant from all sides. the epicentres are not equidistant from all sides.
    Great. Do answer the gold coin questions and dart question with solutions. There has been a lot of confusion over them too.
  • CIVILPRINCESS
    MemberAug 29, 2011
    A circular dartboard of radius 1 foot is at a distance of 20 feet from you. You
    throw a dart at it and it hits the dartboard at some point Q in the circle. What is
    the probability that Q is closer to the center of the circle than the periphery?
    • 0.5
    • 0.25
    • 0.75
    • 1
    answer: .25
    explanation:
    the probability is= (area we need to consider)/ (total area of the dartboard) = (pi (r/2)^2)/(pi r^2) =.25
    P.S: these solutions may be wrong. so CEans please correct them if mistake found.
  • lekhya
    MemberAug 30, 2011
    are u sure this is the new pattern for tcs????????????
    AdministratorAug 30, 2011
    @Lekhya: Yes, TCS just visited our campus and they followed this pattern. We don't think they will change it soon.
  • lekhya
    MemberAug 30, 2011
    ok thank u😀😁
  • lekhya
    MemberAug 30, 2011
    Which colg are u in????????????????????????
  • Neeraj Goyal
    MemberAug 30, 2011
    Thank you very much upload the TCS paper.plz will you upload the answers of these papers
    Most of the questions are solved here by CEan-CivilPrincess, if you don't get some of the other questions, post them here.
  • Krishna Radhika
    MemberSep 1, 2011
    Alok and Bhanu play the following min-max game. Given the expression N = 9 +
    X + Y – Z where X, Y and Z are variables representing single digits (0 to 9), Alok
    would like to maximize N while Bhanu would like to minimize it. Towards this end, Alok
    chooses a single digit number and Bhanu substitutes this for a variable of her choice
    (X, Y or Z). Alok then chooses the next value and Bhanu, the variable to substitute the
    value. Finally Alok proposes the value for the remaining variable. Assuming both play
    to their optimal strategies, the value of N at the end of the game would be
    • 18
    • 20
    • 0.0
    • 27
  • uppala.roshni
    MemberSep 2, 2011
    Hi, I will be facing the TCS online test on Sept 7, 2011 and I donot know from where to start my preparation for. Can anybody please help me.
    AdministratorSep 2, 2011
    uppala.roshni
    Start preparing with the aptitude questions (basic mathematics and logical reasoning along with Data Interpretation and Sufficiency type questions). Interview would be mostly about programming, your project and some totally irrelevant questions: #-Link-Snipped-# 😐
  • ricky.singla
    MemberSep 3, 2011
    can any1 attch the file of question of thoughtworks
  • CIVILPRINCESS
    MemberSep 3, 2011
    one mistake in a problem that i solved.
    CIVILPRINCESS
    lines is
    • 4
    • 1
    • 0
    • 3
    solution:
    explanation:
    inradius(big)
    CIVILPRINCESS
    the excentre is also to be considered since it will be equidistant from all the sides when they are extended. this i had not thought..
    but now there is a new thing that i found.
    if it is an equilateral triangle then the no of excentre points would be three so the total points would be= 1(incentre)+3(excentre) =4.
    but for an isosceles triangle the no of excentres to be considered are just two. therefore no of points = 1+2 =3
    sorry for the confusion guys 😀
  • CIVILPRINCESS
    MemberSep 3, 2011
    Krishna Radhika
    • 18
    • 20
    • 0.0
    • 27
    the answer for this would be= 20
    reason: when we have it like x+y-z the maximum value would be 11 by cleverly placing the numbers. i'll post some examples for it in sometime. its just the same. just add the constant and 11. 😀
  • sarkarpratap
    MemberSep 5, 2011
    @ civil princes
    can u provide pdf of urs solution....?? plz .. i m sittng 4 TCS on 8th... plz buddy hepl
  • lekhya
    MemberSep 9, 2011
    a lady has fine gloves and hat-18 blue,32 red,25 yellow.the lights are out but she could make out its hat or glove in the dark.she takes out an item out of the closet only if she is sure tat it is a glove.how many glove smust she take out to make sure tat she has a pair of each colour????
    pls some one ans this.....................
  • lekhya
    MemberSep 9, 2011
    how come its 11 in the case of x+y-z
    pls explain
  • lakshmidhar
    MemberSep 9, 2011
    hey i have a doubt ex-centre is also equdistant from all the three lines know then we have the answer 4 is it corect or not
  • lakshmidhar
    MemberSep 9, 2011
    since it is given as LINE it can be extendable so that we get 3 excentres and one incentres so answer is 4 otherwise if it is given as LINE SEGMENT ans is 1
  • lakshmidhar
    MemberSep 9, 2011
    if it is LINE it can be extendable so we get 3 ex-centres and 1 incentres so ans is 4. if it is LINE SEGMENT we cannot extend it so answer will be 1 incentre so ans is 1.
  • Rajesh Babu
    MemberSep 9, 2011
    Have u selected
  • lakshmidhar
    MemberSep 9, 2011
    we have tcs on campus on 17th of this month. I came across this doubt when i am preparing for it. Pls clear my doubt
  • cchandansjce
    MemberSep 11, 2011
    Hi Ceans,
    Here s NDS placement papers #-Link-Snipped-#
  • lekhya
    MemberSep 17, 2011
    hi guys.
    i got placed in TCS.thanks for all as u ppl helped me in clearing all my doubts in apti questions.
    thanks once again.
    hoping the hear happy news from u tooo
    bye ppl
    all the best
    MemberSep 18, 2011
    lekhya
    hi guys.
    thanks once again.
    bye ppl
    all the best
    Congrats, but why don't you stay in touch with us... 😀
  • lekhya
    MemberSep 19, 2011
    hi
    ya sure.i will help all of u in clearing ur doubts.pls concentrate on ur technical stuff as most of us were interviewed in tat part
    all the best ppl
    bye
    MemberSep 19, 2011
    lekhya
    hi
    all the best ppl
    bye
    Ha ha.. That's nice... 😀 Thankz, and am from TCS, an year experienced now... 😀
  • lekhya
    MemberSep 19, 2011
    wow u are frm TCS ah?????????????????????????omg i never knew tat...........
  • andenagaveni24
    MemberSep 21, 2011
    hey i am placed in TCS.....very happy ........
    my efforts since may,2011 all came true........😀
  • lekhya
    MemberSep 22, 2011
    congrats dude😁
  • tiny
    MemberSep 24, 2011
    For the FIFA world cup, Paul the octopus has been predicting the winner of each
    match with amazing success. It is rumored that in a match between 2 teams A
    and B, Paul picks A with the same probability as A's chances of winning. Let's
    assume such rumors to be true and that in a match between Ghana and Bolivia,
    Ghana the stronger team has a probability of 2/3 of winning the game. What is
    the probability that Paul will correctly pick the winner of the Ghana-Bolivia game?
    • 5/9
    • 1/9
    • 2/3
    • 4/9 somebody plz answer this one
  • lekhya
    MemberSep 24, 2011
    take one team proability i.e ghana sa 2/3.
    its complement is 1-(2/3)=1/3
    bolivia its winning proability is 1/3
    and losing is 2/3
    not the equation is p(winingof ghana and losing of bolivia)+p(wining of bolivia and losing of ghana)=(4/9)+(1/9)=(5/9)
    this is the ans
    all the best.
    u can clear apti but concentrate in ur technical part during interview.
  • tiny
    MemberSep 25, 2011
    thankx lekhya..
    im also confused in these..plz help !!
    A hollow cube of size 5 cm is taken, with a thickness of 1 cm. It is made of
    smaller cubes of size 1 cm. If 4 faces of the outer surface of the cube are
    painted, totally how many faces of the smaller cubes remain unpainted?
    • 800
    • 500
    • 900
    • 488
    There are two boxes, one containing 10 red balls and the other containing 10
    green balls. You are allowed to move the balls between the boxes so that when
    you choose a box at random and a ball at random from the chosen box, the
    probability of getting a red ball is maximized. This maximum probability is
    • 1/2
    • 3/4
    • 37/38
    • 14/19
    10 people meet and shake hands. The maximum number of handshakes
    possible if there is to be no "cycle" of handshakes is (A cycle of handshakes is a
    sequence of k people a1, a2, ......, ak (k > 2) such that the pairs {a1, a2}, {a2, a3},
    ......, {ak-1, ak}, {ak, a1} shake hands).
    • 7
    • 6
    • 8
    • 9
    36 people {a1, a2, ...., a36} meet and shake hands in a circular fashion. In other
    words, there are totally 36 handshakes involving the pairs, {a1, a2}, {a2, a3}, ....,
    {a35, a36}, {a36, a1}. Then size of the smallest set of people such that the rest
    have shaken hands with at least one person in the set is
    • 11
    • 12
    • 18
    • 13
  • ManishKumarVerma
    MemberSep 26, 2011
    is this the whole pattern or we have other section on aptitude and English also?
    because 35 questions in 80 mins is quite easy i guess..
    only logical reasoning?????
  • CIVILPRINCESS
    MemberSep 26, 2011
    ManishKumarVerma
    yup only one section. only logical puzzles...
  • vinci
    MemberSep 27, 2011
    thanks for the questions i will join you within 7 days after having a look over these questions
  • lekhya
    MemberSep 27, 2011
    cube prob:
    volume=5*5*5=125
    then reduce 2cm
    so v=3*3*3=27
    now 125-27=98
    find faces=98*6=588
    gn 4 faces are painted so area=4*25=100
    then 588-100=488
    balls prob:
    take 2 boxes
    transfer 9 red balls to another box so total balls in green box is(9+10)=19
    now p(red ball in box1)=1
    p(red ball in box2)=9/19
    p(selectin box)=1/2
    now eqn is
    1*1/2 + (9/19)*(1/2)
    verify the method frm ur frnds once........
    gn no cycle of handshakes so n-1=10-1=9
    36 ppl
    so the formula is n/3=36/3=12
    check balls prob. once
  • venkat.sweetie
    MemberSep 29, 2011
    5/9 friend
  • shiva_ch41
    MemberJan 20, 2012
    hiii ,,,can any 1n gimme the explanatn fo this...???
    two vessels contain milk solutions ,,with milk and water in the ratio 2:11 in the first vessel and in the ratio of 5:9 in the second. in what ratio should the contents of these two vessels be mixed such that the resultant mixture has milk and water in the ratio 3:8??
  • sowjipearl
    MemberJun 24, 2012
    Can any1 tell me hw to prep fr placemnts...tcs wl visit my colz in d cumng aug...wt sort of prep needed in tr round...
  • sowjipearl
    MemberJun 24, 2012
    tcs pattern wil b consisting of 3 rounds...
    1.written test consists of 35que 1hr time with .33 negtive marking fr each wrng ans
    2.tr round -fr tat u need to b thorough vth ur prjct n lang(c,c++,java) ds n any 2 subs of ur fav
    3. hr round as u knw testing ur communication levels...so practise fr tat vth ur frnds n u can also prctise by sitting infrnt of a mirror by ans mre sort of que
  • engg.sushantt
    MemberJul 5, 2012
    Krishna Radhika
    • 18
    • 20
    • 0.0
    • 27
    27 is the answer
  • Sourav Das
    MemberJul 2, 2018
    Hey, for latest updated Tcs placement materials WhatsApp me. 8240210592
    AdministratorJul 2, 2018
    #-Link-Snipped-#‍ - No one really whatsApps or sends messages on personal number or email via CrazyEngineers. You will have to wait for answers here.
