tasm psp program
i have written the following code to create two files using psp.name of my program is copytry.And the code is as follows
disp macro msg
lea dx,msg
mov ah,09h
int 21h
endm
.model small
.data
fname1 db 20 dup(?)
fname2 db 20 dup(?)
fhandle1 dw ?
fhandle2 dw ?
buff1 db 20 dup(?)
buff2 db 20 dup(?)
msg1 db 10,13,'file is created$'
msg2 db 10,13,'file not created$'
.code
mov ax,@data
mov ds,ax
mov es,ax
mov ah,62h
int 21h
mov es,bx
mov bx,80h
mov cl,es:[bx]
dec cl
mov bx,82h
lea di,fname1
l1:
mov bl,es:[bx]
mov [di],bl
inc bx
inc di
dec cl
cmp bl,''
jne l1
mov dl,00h
mov [di],dl
lea si,fname2
l2:mov bl,es:[bx]
mov [si],bl
inc bx
inc si
dec cl
cmp cl,00h
jne l2
mov [si],cl
;create first file
lea dx,fname1
mov cx,00h
mov ah,3ch
int 21h
jc l3
disp msg1
mov fhandle1,ax
;create second file
lea dx,fname2
mov cx,00h
mov ah,3ch
int 21h
jc l3
disp msg1
mov fhandle2,ax
jmp exit1
l3:
disp msg2
exit1:mov ah,4ch
int 21h
end
and the output is as follows
C:\Tasm>tasm copytry.asm
Turbo Assembler Version 3.0 Copyright (c) 1988, 1991 Borland International
Assembling file: copytry.asm
Error messages: None
Warning messages: None
Passes: 1
Remaining memory: 460k
C:\Tasm>tlink copytry
Turbo Link Version 5.0 Copyright (c) 1992 Borland International
Warning: No stack
C:\TASM>copytry a.txt b.txt
file is created
file is created
But when i check those files only first file is created and that too in some other format.And second file is not created.Not able to understand.๐
