  • system clock is not working properly
    swathig
    Member
    Updated: Oct 26, 2024
    Views: 1.2K
    Why my system clock is not working properly? Cam any body plz help me to correct it?
    I am using Windows9 os. The clock is not showing correct time from past 15 days. Both the time and date are not showing properly.
    AdministratorMay 23, 2011
    Do you have a dual boot on your computer? If yes, that could be one of the problems.
  • The_Small_k
    MemberMay 24, 2011
    If you are using a system older then 6 years may be the problem is related with your CMOS battery.
  • whiz.kid.aniket
    MemberMay 24, 2011
    swathig
    Replace your battery.
  • Bharath51
    MemberMay 24, 2011
    jst double click on the time button on the task bar........then goto "time zone"
    and then select (GMT+5.30 bombay,Chennai,kolkata, newdelhi)then it will works........😀
  • PraveenKumar Purushothaman
    MemberMay 24, 2011
    If you get your time reset each time when you switch off and start, then its the battery issue. Get a CR-2032 battery and replace it. 😀
