Structural Engineering Project Topics For B.E./B.Tech Students
Here is a list of project ideas for Structural Engineering topics. Students belonging to third year or final year can use these projects as mini-projects as well as mega-projects. This list has been complied after referring to the project ideas that have come across the forum since last few years.
If you have questions regarding these projects feel free to ask them in the replies below. You may also ask for abstract of a project idea that you have or want to work on.
The broad topics could be -
1. High strength concrete
2. Durability of concrete.
3. Optimisation of structures.
4. Punching shear in flat slabs.
5. Long term deflection of concrete beams/slabs.
6. Modern methods of construction.
7. Blast-proof buildings
Some major topics for Structural projects -
- Pushover analysis – cyclic loading, deterioration effect in RC Moment Frames in pushover analysis
- Rehabilitation – Evaluation of drift distribution
- Analysis of large dynamic structure in environment industry
- Theoretical study on High frequency fatigue behavior of concrete
- Seismic analysis of interlocking blocks in walls
- Estimation of marine salts behavior around the bridge structures
- A comparative study on durability of concrete tunnels undertaken in AP irrigation projects
- Prefabricated multistory structure, exposure to engineering seismicity
- Shape optimization of Reinforced underground tunnels
- Properties of Fiber Cement Boards for building partitions
- Behavior of RC Structures subjected to blasting
- The use of green materials in the construction of buildings
- Finite element model for double composite beam
- A new composite element for FRP Reinforced Concrete Slab
- Effect of shear lag on anchor bolt tension in a base plate
- Elastic plastic bending, load carrying capacity of steel members
- FE Analysis of lateral buckling of a plate curved in nature
- Green energy and indoor technologies for smart buildings
- Building environmental assessment methodology
- Numerical study on strengthening of composite bridges
- Strengthening effect for RC member under negative bending
- Effect of negative Poisson’s ratio on bending of RC member
- Macroeconomic cause within the life cycle of bridges
- Long term deflections of long span bridges
- Structural damage detection in plates using wavelet theories (transforms)
- Long-span Bridge Aeroelasticity
- Wind-induced Vibrations of Long-span Bridges
28. Calibration of Numerical Models in Civil Engineering Application
29. Special Aspects of Steel Bridge Structures
30. Soil - Structure – Interaction: Simulation & Experimental Validation
31. Evaluation of seismic performance of a template design RC school building 32. before and after strengthening
33. System identification, model updating and simulation
