@anuraadha-57t1B5 • Apr 14, 2011
when a simply supported beam is acted upon by a concentrated load (W kN) at the centre and uniformly distributed load (w kN/m). the shear force and bending moment is as shown
Sign conventions for a beam
@civilprincess-308hDv • Apr 14, 2011
for the cantilevered beams the loading conditions and the respective SFD and BMD
Always the support reactions are determined by the equation of equilibrium
sum of horizontal forces=0
sum of vertical forces=0
sum of moments= 0 -
@maria-flor-8cAkif • Apr 14, 2011
What do you call the load in parabolic??? -
I guess you are asking about the shape of beam. when a uniformly distributed load acts on a beam the resulting bending moment takes the shape of parabola. -
nope. We have an exam..the load is already in parabolic and we need to draw the shear and moment diagram.... -
yeah there is a loading condition where the load is parabolic distributed.
it has no other names it is just parabolic load
if we take the seismic load acting on the vertical face of dam or the forces due to waves they are all parabolically distributed. 😀 -
Ah..ok. but, how can I solve that kind of problem???? I never expect it to be on our exam in Strength of Materials. -
well i've not solved a parabolic load too. 😔
but i'll refer my books and let you know 😀 -
ok. I'll try to post the problem here.CIVILPRINCESSwell i've not solved a parabolic load too. 😔
yeah do that 😀maria florok. I'll try to post the problem here. -
@anuraadha-57t1B5 • Apr 18, 2011
The beam formulas under various loading conditions. -
statically indeterminate structure - It is a structure where the static equilibrium equations are insufficient for determining the internal forces and reactions on that structure.
Statically determinate structure - [FONT=verdana, geneva, helvetica]It is a structure which can be fully analyzed using the static equilibrium equations.[/FONT] e.g : remove the support B in above figure. -
@khelagor-XnweZz • May 27, 2011
Thanks Anuraadha!
