  • Voltaire
    @voltaire-4MxWke • Jul 30, 2010
    Good question that tests your insight.
    The standard formula is F = kx where k is the proportionality constant (spring constant) and x denotes the amount of deformation from the original length.
    Look up Hooke's law of compression/stretching of a solid rod. You will notice that k corresponds to YA/L[sub]0[/sub] and that x corresponds to DL
    What do you think is the answer to your question and what is your reasoning?
  • samarjeetsaigal
    @samarjeetsaigal-SMCw6m • Aug 1, 2010
    thanks for explaining the formula... i don't know this answer, i only got the question not the answer???
    anyway thanks for the reply
  • Voltaire
    @voltaire-4MxWke • Aug 2, 2010
    You have to try first
    Sorry
  • vvishwaskumar
    @vvishwaskumar-HA8DvG • Aug 13, 2010
    samarjeetsaigalthanks for explaining the formula... i don't know this answer, i only got the question not the answer???
    stiffness will be 20 N/m...its right na...?
  • Voltaire
    @voltaire-4MxWke • Aug 13, 2010
    How did you calculate that answer and what is your reasoning?
  • vvishwaskumar
    @vvishwaskumar-HA8DvG • Aug 16, 2010
    VoltaireHow did you calculate that answer and what is your reasoning?
    hello..
    f=kx..if f is constant and x (length) is half then k will be double..if m wrong then make me right..sorry..!!
  • Voltaire
    @voltaire-4MxWke • Aug 16, 2010
    No need to be sorry ๐Ÿ˜€
    You are right
    Hooke's law defines the spring constant as a characteristic of a spring which is defined as the ratio of the force affecting the spring to the displacement caused by it.
  • 070790vivek
    @070790vivek-09g1Yf • Aug 17, 2010
    vvishwaskumarhello..
    here X does not define the length of spring it defines the deformation of spring on applying load
    in my view there should be other ans๐Ÿ˜•
  • Voltaire
    @voltaire-4MxWke • Aug 17, 2010
    I have to admit that I, too, struggled with this one because L[sub]2[/sub]/L[sub]1[/sub] is a ratio end I would have thought that the ratio would be the same for both coils. Apparently it is not! The shorter spring does not conform to the same ratio as the longer spring if the same force is applied. One has to think of it as a rubber band: a one metre band will stretch to say 2 metres while a [sup]1[/sup]/[sub]2[/sub] metre band of the same material will stretch to only say [sup]3[/sup]/[sub]4[/sub] metres if the same force is applied.
  • Capt Spark
    @capt-spark-xvppcH • Aug 26, 2010
    This is the helical spring stiffness formula:
    [โ€‹IMG]
    If you cut into half, n is halved.. so k gets doubled
    It can be correlated to the stiffness of a uniform bar in tension too (K=AE/L). L reduces, K increases.
    Lots of things are easily available on this question in Google
  • 070790vivek
    @070790vivek-09g1Yf • Aug 28, 2010
    Ya very good this is the correct explanation & answer of this question.
    I m totaly agree with u.
    In study of design of springs( m.d.) we have to use this equation
  • Krishna Moorthy
    @krishna-moorthy-cOobCV • Jul 8, 2016
    thanks for the answerwhich makes me to free from confusion
  • Krishna Moorthy
    Thanks for the information
