  • harmanpreetsingh
    @harmanpreetsingh-EjdtNA • Feb 18, 2010
    Hemant.oistCan any body inform me that how an Ejector works in Air cooled condesers??
    The temperature of exhaust gases from simple cycle gas turbine generation sets (GENSETs) is usually very high (around 500 °C), and a heat recovery steam generator (HRSG) is often used to recover the energy from the exhaust gases and generate steam. The generated steams can be either used for many useful processes (heating, drying, separation etc.) or used back in the power generation system for enhancing power generation capacity and efficiency. Two well-proven techniques, namely steam injection gas turbine (STIG) and inlet air cooling (IAC) are very effective features that can use the generated steam to improve the power generation capacity and efficiency.
    Since the energy level of the generated steam needed for steam injection is different from that needed by an absorption chiller to cool the inlet air, a proper arrangement is required to implement both the STIG and the IAC features into the simple cycle GENSET.
    In this study, a computer code was developed to simulate a Taipower’s Frame 7B simple cycle GENSET. Under the condition of local summer weather, the benefits obtained from the system implementing both STIG and IAC features are more than a 70% boost in power and 20.4% improvement in heat rate.
  • Hemant.oist
    @hemantoist-kz809Z • Feb 19, 2010
    This is for Gas turbine. In my case turbine is steam turbine and steam ejectors are used here to create the vaccum all over the condenser. What is the need to create vaccume?? and how is it created by ejectors.
  • bharatmaharana
    @bharatmaharana-4XNvIF • Feb 20, 2010
    air ejector is one type of ventury. when velocity of any stream increase, pressure nearby area will decrease. so in air ejector ,in meddle are high velocity steam are passing which create vacuum in the surrounding area.
    motive fluid may be steam or air or any other fluid.
