Square to sinewave convertor
awaiting
@awaiting-ipQI42 โ€ข Oct 19, 2024
Hello everyone,
i have a 312MHz square wave oscillator and want to generate a 312MHz sinewave with it.i am stuck at this point and dont know how to proceed.i googled it but did not get much info,if anyone can provide some circuit or any ic capable of it,that would be very valuable info for me.
Thanks in advance
    @harshad-ukH5ww • May 13, 2011
    I am not sure but i think by using IC 555 we can change into Sinewave, but still need some strong detail. try to find the circuit based on IC 555.
  • PraveenKumar Purushothaman
    @praveenkumar-66Ze92 • May 14, 2011
    Try this...
    [โ€‹IMG]
    For more information, please refer to: #-Link-Snipped-#
    Sinewave Generation Techniques have got a good amount of techniques to generate sinewave from various other inputs. Do check this out... #-Link-Snipped-# Hope this helps... ๐Ÿ˜€
  • awaiting
    @awaiting-ipQI42 • May 16, 2011
    Thank you guys for your replies!
    i checked the datasheet of ic555,i dont think it can be used for 312MHz.Moreover i have the square wave and only need to find a way to convert it.
    Sinewave Generation Techniques have got a good amount of techniques to generate sinewave from various other inputs. Do check this out... #-Link-Snipped-# Hope this helps... [โ€‹IMG]
    i checked both the links.Few resistor values obtained in the first link are too low,one being 0.3ohms
    In the other link suggest using a DAC but the maximum output frequency provided by them does not exceed 130MHz
    @praveenkumar-66Ze92 • May 16, 2011
    You can use your formula to calculate what the required resistance and implement right???
  • everett.pattison
    @everettpattison-3yhnjP • May 17, 2011
    Just to be clear, are looking to change a square wave that you already have into a sine wave? Or are you looking to generate a sine wave at that frequency?
    @praveenkumar-66Ze92 • May 17, 2011
    I guess he is asking the first one... Changing...
