@thebigk • Nov 25, 2008
babloo0311Hi friends,
what is the difference between delete and trancate commandIts 'truncate', I think.
@manupep-fYm2v7 • Nov 25, 2008
Is there any command 'delete' ?
I think 'drop table' is the command used to delete one table.
'truncate' will delete only the contents of the table . The table structure should remain. we can add datas further. -
@prasad-aSUfhP • Nov 25, 2008
Well, you can also use delete from <table_name> command to delete only the contents of the table. Schema will remain intact though.
@manupep-fYm2v7 • Nov 26, 2008
oh! yes 'delete' is there to delete rows according to condition.
@shalini-goel14-ASmC2J • Nov 26, 2008
Hi Babloo
1. TRUNCATE : You can't use WHERE clause
DELETE : You can use WHERE clause
2. TRUNCATE : You can't use WHERE clause
3. Delete - delete deletes the records from table it can be rollbacked also you can give the where condiition to it.
Truncate - delete all records from table There is no rollback it always commit without giving the commit command
TRUNCATE is a DDL command and cannot be rolled back and All of the memory space is released back to the server. It can not use the Where conditions. DELETE is a DML command and can be rolled back. here can be use where conditions. TRUNCATE is much faster but don not use it if delete can work. -
@babloo0311-J22PBc • Nov 26, 2008
yeah thanks buddy
oh! so much infos .Thanks shalini.
@shalini-goel14-ASmC2J • Nov 27, 2008
Always welcome ๐ .
Sorry for Duplicate points:
DELETE : You can use WHERE clause -
@babloo0311-J22PBc • Nov 27, 2008
yeah no probs
@prasad-aSUfhP • Nov 27, 2008
Wow! Good tips Shalini!!
@ziasepsis-0NGPzn • Dec 30, 2008
Truncate table does not support the Where clause. In addition, the Truncate table statement does not fire a trigger. When truncate is used, the deleted rows are not entered in the transaction log. there fore it can't be rolled back. when the delete command is used , it creates a transaction log file which help you in the process of rollback.
the syntax of truncate statement is:-
truncate table table_name
the syntax of delete statement is:-
delete table_name
both the statements is used to delete all the records form the table
correct me if am wrong ๐ -
@heart-hacker-nZz25T • Dec 30, 2008
I think you got your ANS ๐
