    @thebigk • Mar 5, 2012
    RAANAIn C# I want to write the query for copying one table data into another table, can anybody help me?
    Share the code you've written so far ๐Ÿ˜€
  • vinci
    @vinci-e4PtMU • Mar 6, 2012
    you need sql code
    INSERT INTO TABLE2 (COL1, COL2, COL3) SELECT COL1, COL4, COL7 FROM TABLE1โ€‹try this โ€‹
    with ADO.Net concepts apply the above query over database table and you get desired results
  • PraveenKumar Purushothaman
    @praveenkumar-66Ze92 • Mar 7, 2012
    Bulk Copy feature of ADO.NET might help you take a look at that: #-Link-Snipped-#
    This is the simplest way to copy a table into another (new) table in the same SQL Server database. This way of copying does not copy constraints and indexes.
    select * into <destination table> from <source table>
    Example:
    Select * into employee_backup from employee
    We can also select only a few columns into the destination table like below
    select col1, col2, col3 into <destination table>
    from <source table>
    Example:
    Select empId, empFirstName, empLastName, emgAge into employee_backup
    from employee
    Use this to copy only the structure of the source table.
    select * into <destination table> from <source table> where 1 = 2
    Example:
    select * into employee_backup from employee where 1=2
    Use this to copy a table across two database in the same Sql Server.
    select * into <destination database.dbo.destination table>
    from <source database.dbo.source table>
    Example:
    select * into Mydatabase2.dbo.employee_backup
    from mydatabase1.dbo.employee
    Any one of the following methods can be employed to copy a table into a destination database on a different SQL Server.
    1. Data Transformation Service (DTS) รขย€ย“ SQL Server 2000.
    2. SQL Server Integration Service (SSIS) รขย€ย“ SQL Server 2005
    3. SQL Server รขย€ยœExport Dataรขย€ย task. รขย€ย“ SQL Server 2000/2005
    4. Create a linked Server of the destination SQL Server on the source SQL Server and then copy the table. รขย€ย“ SQL Server 2000/ 2005.
    5. We can also use <a href="https://vyaskn.tripod.com/code.htm#tagit" target="_blank" rel="nofollow noopener noreferrer">My code library (SQL Server T-SQL code samples, snippets, examples, tips, tricks, stored procedures, user defined functions, VB programs): Narayana Vyas Kondreddi's home page</a> to generate data insertion scripts and then run the insert scripts.
    6. I almost forgot this ๐Ÿ˜‰ you can open the source table , select the row(s), copy (ctrl + C) the row(s), open the destination table and then paste (ctrl + V) the row(s).
