@ramani-VR4O43 • Sep 7, 2014
I have not used PLL for any application. As the name implies the controller output phase is locked to the input signal.
May be these will help:
#-Link-Snipped-# -
@joy-8GOU7k • Sep 8, 2014
sir..basically im designing an custom ic in multisim software...it accepts only (* *.cir) files...the above link which you have provided above has a model in it...if i use that..it gives me the warning message as displayed below...(i am new to spice models...)😔
Section: A
Warning: the model data of an analog component must be in one of the formats:
<Empty> with 2 pins or 4 pins
.Subckt <Model_Name>
.Model <Model_Name> D with 2 pins
.Model <Model_Name> NPN with 3 pins
.Model <Model_Name> PNP with 3 pins
.Model <Model_Name> NJF
.Model <Model_Name> PJF
.Model <Model_Name> NMOS
.Model <Model_Name> PMOS
.Model <Model_Name> NMF
.Model <Model_Name> PMF
.Model <Model_Name> SW with 4 pins
.Model <Model_Name> LTRA with 4 pins
.Model <Model_Name> URC with 3 pins.
.Model <Model_Name> _code_model_name_(_Param.).
Continue?
please give me directions...!!!!! -
@ramani-VR4O43 • Sep 8, 2014
My experience with controls is as an end user in process control as a ChemE. This did involve working with electronics people to develop application specific controls. My role ended with giving a design brief on what was the performance expected and any alarms/alerts needed in case of abnormal situations.Sufficient Gracesir..basically im designing an custom ic in multisim software...it accepts only (* *.cir) files...the above link which you have provided above has a model in it...if i use that..it gives me the warning message as displayed below...(i am new to spice models...)😔
Section: A
Continue?
While doing this one does pick up a smattering of what the developers are doing. That is a far cry from being able to give you the kind of help needed. From a common sense point, the warning is only alerting you to provide input data on components in a particular form for that specific model in that link.
You have to go to some one in your line for expert help.
Probably #-Link-Snipped-# can help. -
thank you sir.... -
@harshad-ukH5ww • Sep 10, 2014
Sorry for the late reply #-Link-Snipped-# Sir !
Are you looking for Pspice model ? PLL might be easily available for MATLAB Simulink. But I have not deep knowledge into that.
You looking for any specific chip? -
@joy-8GOU7k • Sep 11, 2014
sir im trying to implement fsk demodulator (using pll) in multisim.but i cant find pll in multisim software..so i tried customizing it in component wizard of multisim.there im in need of a spice model of pll to implement it...Harshad ItaliyaSorry for the late reply #-Link-Snipped-# Sir !
@prototype-G9Gn5k • Sep 12, 2014
Check this thread out -> #-Link-Snipped-#
