  • shubhankar
    @shubhankar-CeulhT Mar 31, 2011
    WATER POWERED CLOCK
    No batteries at home to run the clock in time of emergency? Need to know the time urgently? Here is the solution to your problem. The clocks powered by water. Once you pour water at the designated place, the clock starts working within a few seconds until the water dries out. If you place some flowers in the water it will work as an alarm clock. Now isn’t this enthralling? The first ever water clock used is dated back in 1500 B.C. Later it was used by the Roman and Greek engineers between 100B.C to 150 A.D on a wide scale.
    Further more the Chinese engineers put forth their own designs by A.D 1088. these clocks were as tall as 30 feet.
    Now, having known this, let us get familiar with the working of this clock:
    1. Water is not the source of power to these watches.
    2. The difference in the electrode potential between the anode and the cathode produces electricity.
    3. These anode and cathode are inserted into water (or potato).
    4. This results in the ionization of the electrolyte and electrons are set free.
    5. Metals such as copper and zinc are used for electrodes.
    6. It appears a bit different but it is just like a battery.
    7. The clock anyway draws a very little amount of electrons released in the water.
    8. Thus even a glass full of water can drive the clock for a few months.
    9. The function is similar to that of a simple galvanic cell.
    Thus the clock doesn’t particularly use water but some reactive electrodes which make the provision to power the battery. The internal converter simply extracts electrons from water molecules and provides a steady stream of electrical current acting as a fuel cell to generate power to the clock.
    And guess what? This clock is available in wide ranges of price starting from $3 to $25. Generally alarm clocks are a bit costlier.
    what do you say CEans?
  • shubhankar
    Cable gland M thread:
    it permits the cable to enter the enclosure and relieves a lot and strain on the cable.
    it has the highest protection class of IP68-5bar.
    operating temperature range is -4 deg F to 212 deg F.
    it is available in variety of materials, colors and sizes as per the consumer requirement.[​IMG]
  • shubhankar
    @shubhankar-CeulhT Apr 1, 2011
    " ZEBRONICS" has launched a portable multimedia player. It is named as STEM
    It has a MicroSD card support
    User can use this card upto 16 GB of Capacity
    It also does some multitasking by functioning as the Card reader/ Writer for MicroSD cards
    Can be used as a pen drive to transfer data.
    It has no inbuilt memory. It gives us the choice to select the memory we requuire.
    Has inbuilt lithium battery.
    5 buttons on the front panel of the player for navigation.
    It has the on/off button and USB on the side
    It comes in 4 colors viz red, green, blue and black with headphones also.
    This player gives Music for every pocket
  • shubhankar
    @shubhankar-CeulhT Apr 5, 2011
    Denon-AH-D1100:
    hey people. today in this era our favourite pass time is to plug in th ehead sets and listen to the music. so here is the stunning AH-D1100 for you. let us have a look at what it has got.
    The engineers seem to have worked hard on the ergonomics because it has a remarkably comfortable design. It gives a warm and a relaxed sound, it is supersensitive and rugged in construction. The only thing is that the bass may be a bit heavy for some listeners.It has been provided with an extension cable and a 1/8" to 1/4" adapter which allows the headphone to be connected to the home stereo. The head band and ear cup suspension are made up of semi gloss, silver and super lightweight plastic. The ear cup is moderately padded with soft material. It also has a 3 feet extendable cord and has a 1/8" jack. It does not weigh more than 6.7 oz. The price is $ 199.99...
    @thebigk Apr 5, 2011
    Moving to CE Review section. Why not start a new thread for each gadget? Others will be able to build a discussion for each gadget 😀
