  • Solve this Sql Query -Part 2
    Manish Goyal
    Manish Goyal
    @manish-r2Hoep
    Updated: Oct 26, 2024
    Views: 1.2K
    Continued to my previous query #-Link-Snipped-#
    Let us make this query a little bit tricky
    Say i want to develop a single query, through which i can extract data of all the employee having 5th highest salary .
    Remember it should be single query ,that next time if i want salary of employee having maximum salary among all,it should display it too
    Note :-you have to mention which variables in query are required to be modified dynamically every time
  • ISHAN TOPRE
    MemberJun 1, 2011
    I know a little. Is it
    Select * from employee where Salary< salary1, salary 2, salary 3, salary4
    ?? I do not know much but we can define salary 1,2,3,4. In this way we can get the highest salaried employee's data too.
  • Sahithi Pallavi
    MemberJun 2, 2011
    @ishu : that's not the right answer I guess because if we want the details of the employee having 20th highest salary, then its difficult to mention all the numbers..
    I don't know the answer, I am trying now!
  • synergynext
    MemberJun 3, 2011
    SELECT * FROM table_name a
    WHERE 5 = (SELECT COUNT(rowid)
    FROM table_name b
    WHERE a.rowid >= b.rowid);
    a and b are alias of same table. you can replace 5 by any number you want. This type of questions is very popular for freshers' interviews 😀
  • synergynext
    MemberJun 3, 2011
    Correction:
    didnt read highest salary earlier:
    correct solution is as follows:
    SELECT MIN(salary)
    FROM (SELECT salary FROM employees ORDER BY salary DESC)
    WHERE ROWNUM <= 5;
  • Manish Goyal
    MemberJun 3, 2011
    That's nice answer,
    I want single query ,you can modify it dynamically in order to get right answer.
  • synergynext
    MemberJun 3, 2011
    SELECT rownum, salary FROM employee
    GROUP BY rownum, salary HAVING rownum = 5
    enjoy
  • Manish Goyal
    MemberJun 3, 2011
    synergynext
    enjoy
    Ok say i have deleted employee data whose id is 5 ,then will this query work?
  • synergynext
    MemberJun 3, 2011
    I hope you are aware of "What Rownum is"!
  • Manish Goyal
    MemberJun 3, 2011
    synergynext
    hmm actually i am aware of Mysql only ,but this query is not working there,
  • synergynext
    MemberJun 3, 2011
    hmmm,
    If you have mysql installed, can you try this one and let me know if it works
    SELECT * FROM employee ORDER BY salary DESC LIMIT 5,4
  • synergynext
    MemberJun 3, 2011
    or LIMIT 4, 5
    whichever works haha
  • synergynext
    MemberJun 3, 2011
    goyal420
    rownum is a pseudo column in Oracle sql plus. Suppose if you run the query that uses rownum, and delete that record. Now when you retry the query, you will get new output which will be 5th highest salary at that time.
  • sookie
    MemberJun 7, 2011
     select * from (
    select name,salary,dense_rank() over(order by salary desc) dr
    from employee
    ) where dr = :rankOrder
    Enter rankOrder as 5 to get the output .
  • synergynext
    MemberJun 8, 2011
    His initial requirement was to have a single query, not a nested one.
    In my opinion this one is the answer:
    Later he asked it for MySQL, so this would run fine on MySQL.
    SELECT * FROM employee ORDER BY salary DESC LIMIT 4,5
    Both are single queries.
  • sookie
    MemberJun 9, 2011
    @synergynext "rownum" fails when you have two employees having same salary say '35000' as 5th highest salary. It will give you one record always in spite of having many two.
  • PraveenKumar Purushothaman
    MemberJun 28, 2011
    I guess the best SQL Query would be:
    SELECT * FROM `emp` GROUP BY `salary` DESC LIMIT 4,5
