Solve the Programming Bits
What is the output of the following programming bits? You have to give Explanation to your answer.
1. int i=10;
printf("%d%d%d",i,i++,++i);
2. printf("Enter two values a and b:"):
scanf("%d%d",a,b);
printf("%d+%d=%d",a,b,a+b);
  • Manashree Thokal
    @manashree-7mZH3V • Aug 8, 2011
    Giving a try.
    1. 10 10 12
    Explanation:
    -Initial value of i will be printed i.e. 10
    -Value of i will be printed i.e. 10 and then incremented i.e. 11
    -Value of i will be incremented i.e. 12 and then printed.
    2. scanf syntax is incorrect. So it will give an error.
  • Sahithi Pallavi
    @sahithi-oJZaYj • Aug 8, 2011
    manashreeGiving a try.
    1. 10 10 12
    Explanation:
    Yeah even I thought the same. If this is the answer, why the companies ask this kind of simple questions? This is the question asked by IBM. Try executing it once, It shows some other output.
    Error? What kinda error you will get? You won't get any output?
  • Manashree Thokal
    The numbers wont get accepted as the syntax is incorrect.
    It should have been- scanf("%d%d",&a,&b);
  • Sahithi Pallavi
    manashreeThe numbers wont get accepted as the syntax is incorrect.
    Yeah you are right, the given input numbers wont get accepted. But could you please tell me what specific Error/ Warning you will gete if you execute this?
  • Sahithi Pallavi
    @sahithi-oJZaYj • Aug 9, 2011
    why I am asking that many times because I executed that statement - the input values that I have given was not accepting, it is taking some other values instead.
    I executed this in turbo c++3.0 and I got this output :
    Enter two values a and b : 2 3
    1224 + 1230 = 2454
  • Pensu
    @pensu-8tNeGU • Aug 9, 2011
    @sahithi: scanf functions is used to accept the values. If you wont give it any it will assume it by itself. So, the second program doesnt show errror, it jus give you some garbage output. The basic thing happening here is it scans the value of "a" here and as you havent initialize it, so basically its a garbage value. Hence the output.
    For the first question, i have a very convincing explaination. In printf function what actually happens is it starts executing the statements from right to left. Now in this question we have i=10. First expression from right is ++i, so it first increments the i and makes the value 11. Now next is i++, it prints 11 and makes i=12. Now next is i which is simple 12.
    P.S: These type of questions are compiler dependent. Different compiler shows different results. I am using Turbo C to explain the outputs.
  • Sahithi Pallavi
    @nicepeeyush : You are perfectly right.
    Here are the another two questions.
    3. main()
    printf("hello");
    main();
    how many times it will print? Give the output with explanation.
    4. what will be the output?
    int main()
    char a,b;
    printf(“%d%d%d%d”,sizeof(‘A’), sizeof(‘NULL’), sizeof(‘a’), sizeof(main));
  • Pensu
    Both are compiler dependent. In the first one: Yes, you can call main function recursively, no problem in that, provided your compiler allows you to do it. So, the answer is infinite. But as i said above depending on your compiler you can even get an error.
    For the second question, first three are easy. All the values inside ' ' are considered as integers. So it will print the size of integer. If you will use " ", then it will print the size of character. Now the fourth term, here compiler comes. Some compiler wont allow this operation. But as you have to answer it so what other compilers do is that they give every function a random size. No matter what you write here, main, scanf, printf, user defined function or anything the result would be same. Although if you write main() it will give you the size of the returning value i.e. if you are going to write int main() and then evaluate sizeof(main()), it will print 2 or 4(depending on 32 or 64 bit compiler).
  • Sahithi Pallavi
    @nicepeeyush : Hats off to you.
    Here are some more questions..
    5.what is the output?
    #DEFINE xyz(exr)printf(“exr=%d”,exr)
    main()
    int x=3;y=2;
    xyz(x/y);
    6.#define hello(x,y) printf(#expr"%d",expr);
    main(){
    float x=1,y=2;
    expr=x/y;
    hello(expr);
    7. main(){
    main();
  • Pensu
    5. Using pre processor directive, it will just replace the expression xyz(x/y) with defined value and exr with x/y and the important thing is that all of this happens before compilation(the reason why they are called pre processor directives). So basically when program goes to compiler its a correct program where i am printing division of two integer values.
    6. Syntax error, you can't define a micro inside another one. Nesting of micros is not allowed.
    7.Infinite loop, as i said above recursive calling of main is possible.
  • mcxfever
    @mcxfever-A6V9P4 • Aug 10, 2011
    10, 10, 12
    Here are some question in C++
    class Test
    public:
    void DoSomething(StatusInfo& rStatus);
    StatusInfo& rStatus();
    const StatusInfo& Status() const;
    private:
    StatusInfo& mrStatus;
  • Sahithi Pallavi
    @sahithi-oJZaYj • Aug 18, 2011
    8.main()
    int i=0;
    for(i=0;i<20;i++)
    switch(i)
    case 0:i+=5;
    case 1:i+=2;
    case 5:i+=5;
    default : i+=4;
    break;
    printf("%d,",i);
    9. main()
    int c[ ]={2.8,3.4,4,6.7,5};
    int j,*p=c,*q=c;
    for(j=0;j<5;j++)
    printf(" %d ",*c);
    ++q;
    for(j=0;j<5;j++)
    printf(" %d ",*p);
    ++p;
  • silverscorpion
    @silverscorpion-iJKtdQ • Aug 19, 2011
    8. I think it will print
    17 21
    9. 2 2 2 2 2 2 3 4 6 5
  • Reya
    @reya-SMihdC • Aug 20, 2011
    8. It will throw an error.None of the case labels are within the switch statement.
    Output will be 16,21 after debugging.
  • Reya
    9. 2,2,2,2,2,2,3,4,6,5.
  • simplycoder
    @simplycoder-NsBEdD • Aug 22, 2011
    @Reya: for question number 8, I agree with the first part that the compiler will spitout an error, however, the output is dependent on how you debug the particular statement. Its just the matter of parantheses.
    int i=0;
    for(i=0;i<20;i++)
      switch(i)
           case 0:i+=5;
           case 1:i+=2;
           case 5:i+=5;
           default : i+=4;
           break;
    printf("%d,",i);
    The code might be adjusted like this aswell, to which I think the output is 22,
    Am I missing something?
  • Reya
    @reya-SMihdC • Aug 22, 2011
    @Simplycoder: Oops! You are right 😀
  • Rupam Das
    @rupam-das-wW5CvN • Sep 1, 2011
    what if a and b are declared as pointers?????
    int * a,*b??? Then scanf syntax is perfect as the bit does not show a and bs definition
    Edited: Oops Threaded reply not working or what? wanted to answer for 1st question)
  • simplycoder
    @simplycoder-NsBEdD • Sep 3, 2011
    Hello everyone..
    I dont know whther this falls under programing bits category, but if you want some practice for programing in C or for that matter any language, you can try out the programs from #-Link-Snipped-#.
    I have personally solved every one of them and after solving them, I got a good grasp of control structures.
