Solve The Ant Problem
Got this problem from a friend through IM. Solve it !
An ant is at a fixed end 'P' of a 1 meter-long rubber band.
Just as the ant starts walking along the rubber band at a constant 1 cm/sec,
the other end 'Q' is pulled away from 'P' at a steady speed of 100 cm/sec.
Assume a uniformly stretching, infinitely elastic rubber band is used in this puzzle.
Will the ant ever reach 'Q', and if yes, when?
-The Big K-
  • crook
    @crook-0PFkJv • Apr 16, 2007
    To the best of my knowledge, the problem was discussed in Mindsport section of TOI! heck I don't know the answer.
    I think the ant should take infinite time to reach the other end.
  • Rocker
    @rocker-ZpZLKM • Apr 16, 2007
    Since the ant is located on the rubber, the total distance that the ant has to cover is just 100 cm. The total time taken will be 100 cm / 1 (cm/sec) = 100 sec.
  • LORD_EC
    @lord-ec-EvZ5RZ • Jun 26, 2007
    @the_big_K
    Is the answer given by rocker is correct ???
    This is what i think.
    The aunt is at a fixed point P.Now the other end,Q is moving away from aunt(or point P) at the speed of 100 cm/sec.So in one second,the point Q will be 100cm that means Q is now 200cm apart from P.And after one more second,it will be at 300cm apart.Thus the distacne PQ will go on increasing.And the speed of aunt is not sufficient to compensate for that.
    Am i right or am i misinterpreting the puzzle.
    Anyone please clarify..
  • ankitvirmani
    @ankitvirmani-kI33aF • Jun 27, 2007
    This problem can be correlated to a person walking@1m/s on a 100m long train.the person will cover the length of the train in 100s irrespective of the speed of the train.
    Now people will say that here the entire rubber band is not moving, it is getting stretched.Hence the ant which is moving at an absolute speed of 1cm/s will be assisted by the stretching of the rubber band (increasing its absolute speed) and will cover the distance in 100s.(the increasing of speed can be justified if you look at stretching on a microscopic level)
    ๐Ÿ˜
  • satheesh27887
    @satheesh27887-baQnlX • Jul 27, 2008
    The ant never reaches the end Q.....
    bcoz the band is infinitely elastic rubber band......
    So it keep on stretches......๐Ÿ˜
    Do u think, It is correct??????
  • Prasad Ajinkya
    @prasad-aSUfhP • Jul 31, 2008
    The problem has not been interpreted correctly. Assuming uniform elasticity, the length of distance the ant has to cover is increasing by 100 cm/s ... but please note, that in the first second, the ant has covered 1cm, the band is 200cm long ... and the ant has covered 2cms (since that 1cm is now 2cm ... due to stretching!!).
    Then the ant goes ahead by 1cm, the band becomes 300cm long .. the distance behind the ant is 5cms. Then it goes ahead by 1cm, the band becomes 400cm long ... the distance behind the ant is 8 cms ahead.
    Time Distance Covered %age
    1 100 1 1%
    2 200 3 1.5%
    3 300 5 1.66%
    4 400 8 2%
    Looks like the ant is making some progress after all ๐Ÿ˜€. I say it will reach the end. And you know what ...
    Moral of the story - Determination gets you there.
  • banu
    @banu-d7GxOI • Aug 11, 2008
    no it won't reach Q
    bcoz it will fall down as the band is stretched.
    banu
  • anuragh27crony
    @anuragh27crony-mb8hAE • Aug 11, 2008
    Yeah i agree with the solution provided by Kidakaka...
    Since the rubber is uniform ....so the distance travelled by the ant also get's streched.....
  • shubhrajeet tiwa
    @shubhrajeet-tiwa-HbUaIL • Nov 26, 2009
    distance -time relation for ant:
    (1)t*(100/100)*t
    as per second increment of unit section rubber length is (100/100)*x where x is its orignal length
    therefore increment in given section in time t is:
    1*x*t
    hence length reletion with time is =100t
    left distance=100t-t*t=let's say "r"
    ant rech at Q when
    100t-t*t=0
    therefore
    t=100sec
  • Saandeep Sreerambatla
    @saandeep-sreerambatla-hWHU1M • Nov 26, 2009
    Very nice answer Kida!!
    Its beyond imagination!!!
  • rgc437@gmail.com
    @rgc437-at-gmailcom-iBbZhR • Jan 2, 2011
    no it won't reach the Q
  • rgc437@gmail.com
    ya it's beyond the imagination.
  • rgc437@gmail.com
    wat could be the answer then
  • makru921
    @makru921-Am65Ah • Jan 2, 2011
    Very very interesting question!! I strongly believe that the ant will reach the end at one stage as Kida explains, but it will take a very very long amount of time.. The fact we have to consider here is the ant's position relative to the stretching of the rubber band. I dont know how to explain it, but i'm pretty sure it will make it! I would love to see someone bring out any solid proof..
  • shreyasm89
    @shreyasm89-jGobVm • Jan 3, 2011
    The ant will surely reach the end at some point of time. As the band is being stretched, even the ant's position from the starting point increases at the rate of 100 cm/sec. Now in the same 1sec, the ant has covered a dist. of 1 cm. So actually the ant is covering a distance of 101 cm/sec. I don't know the exact time but it should reach.
  • suyash
    @suyash-2N6gPP • Jan 4, 2011
    The ant will reach the end, albeit after a very long time. Will post a detailed mathematical solution once I complete it.
  • ISHAN TOPRE
    @ishan-nohePN • Jan 6, 2011
    Its simple.The ant would take same amount of time if the rubberband had not been streched.
    Because,speed of ant would be (100+1)cm/sec.
    For example:If we are walking inside a in a moving train our net velocity is algebraic addition of{velocity of train+our own velocity};-)
