solar tracking system
Neha@Gupta
@neha-at-gupta-92gb5d โ€ข Oct 26, 2024
Neha@Gupta submitted a new project:
#-Link-Snipped-# - The main objective is to provide max electrical energy for the light appliances
The main objective of this project is to development of an automatic solar tracking system whereby the system will cause solar panels will whereby it will caused the system is able to tracks the maximum intensity of Sunlight. It is a uncomplicated source of solar energy production and produce maximum solar power. It is used where there is no electricity.This project is based on keil microvision software with embedded dot c programming.
    @thebigk • Oct 16, 2014
    Welcome to CE, #-Link-Snipped-# . I guess you should add a few more details / source code to your project.
  • Shivam Agrawal
    @shivam-ETMZRN • Oct 29, 2014
    can u please tell about the efficiency of your systems, i mean comparing it with normal solar system, becauze your motor will consume a good amount of power for ratating , and its working when sum is not there?
  • praveen battula
    @praveen-battula-4msByF • Dec 6, 2014
    good project ...related to renewable resources
  • a.alandkar
    @aalandkar-R9Nf1k • Jan 19, 2015
    Hello Neha,
    What kind of algorithm you are going to implement, I mean are you going to use light sensors or going to implement the task using look up table.?
    I already have done this project 5 years back. If you need any help, feel free to ask.
