  • Solar panel design
    Abrar Hazoor
    Member
    Updated: Oct 25, 2024
    Total load 5600watts
    5600 x 7 =39200wh
    duration of sunlight = 7 hours
    How many solar panels required of 200 watt and 12 volt???
    How many batteries required of 200amp???
    and also inverter which is used for converting DC to AC???
    Please remember that solar panels are specified for peak insolation, which will not hold for all seven hours. Clouds can modify the out put considerably.
    Having said that, each panel gives you 2400W. Panels needed /2400. I think the arithmetic is fairly simple for the rest of the calculation also. Please put in factor of safety and battery charge-discharge efficiency to arrive at batterycapacity.
  • Abrar Hazoor
    MemberJul 13, 2012
    each panel give 2400W how???
    ahazoor
    Sorry my mistake. I misread your post. 2400WHr is your battery capacity.
    You will need 5600/200 = 28 panels.
    I suppose you meant 12v 200 amp hour batteries. Each battery is 2400whr.
    For 39200whr you need 39200/2400 = 17 to the nearest whole number
    This assumes that everything is at peak power and 100% efficiency.
    In actual use you may have to use 40 panels and 25 batteries.
    Since the load is 5600W choose an inverter that is at least 6KW rated.
  • Abrar Hazoor
    MemberJul 14, 2012
    thnx for info,
