  • Software to check MicroProcessor code?
    Updated: Oct 26, 2024
    Views: 1.0K
    Hai freinds.......
    Is there any software to check my microprocessor code in the desktop rather than doin in an aet-kit and also pls suggest me some tutorial sites for me....
  • bill190
    MemberJul 29, 2010
    Re: MicroProcessor
    Might help if you said which microprocessor/microcontroller you are using???
    Pic microcontrollers have simulation software as part of the MPLAB IDE if you are using a Pic. To use that, in MPLAB, go into Debugger, Select Tool, then MPLAB SIM.
    Here are some basics on that...
    I know there is one software called 8085 Simulator is used for the same question you are asking.
    and the its available with the 8085 Microprocessor Book written by R.S Gaonker.
    Try to get that CD from your College Library.
  • abhinaykumar
    MemberJul 31, 2010
    thanx god father i will check it.........
  • ibitechs2005
    MemberSep 30, 2010
    Try this address #-Link-Snipped-#
  • Saandeep Sreerambatla
    MemberSep 30, 2010
    I tried the above site , what ever I search I get no results!
    Is this a valid site?
    English-Scared
    You are right Sandy this one is not valid or there is some mistake in posting the link.
  • shreyasm89
    MemberOct 2, 2010
    Plz chek out MPASM.....it is I think the only simulator available for 8085-8051 simulation. You will have to write the code in Notepad and then save the file with .asm extension. This is because the interface is Command-Line based.
