@gohm-F3UUpP • Feb 10, 2010
Re: six stroke
What application of the engine are you proposing? Do you know how many degrees you need to reduce? -
@shrinkdworld-WWdBBc • Feb 11, 2010
ya explain deude
@070790vivek-09g1Yf • Feb 11, 2010
in a 4 stroke in the inside temperature reaches up to 558 degree centigrade
then it is very difficult to remove all the heat by application of air and oil
i think u can use water also for this purpose as it is used in cars or any coolant -
@tanny-7TRyKz • Feb 12, 2010
but the difference in timing of strokes is very less so it is practically not possible to decrease temp so fast.
anu_mech OP
@anu-mech-XkawyC • Feb 13, 2010
if instead of instantaneous introduction of water, atomized oil water mix is sprayed from the piston head, it'll reduce rate of cooling. Therefore fluctuation in thermal stresses vl reduce.
