Should I partition my mac hard drive?
The way Mac handles files is a bit messy.
As data changes through daily use, photos, text files and other things get mixed up with system files. Despite Mac OS Xโ€™s default defragmentation work, this is a problem for disk performance and, inevitably, system performance at large.
Should I partition my mac hard drive? What are the long term gains?
PS: Expert advice will help beginners with Mac. ๐Ÿ˜‰
  • AnarchistBits
    @anarchistbits-jhF4Gy Jun 12, 2011
    Mac is based upon Unix OS. Partitioning in Unix allows would allow you to separate the system files and user files. One partition can be made for "/", the partition the system boots from. Another partition can be made for "/home", the partition where user accounts are stored. That's one possible way to do it. You will get a boost in performance because the user files are isolated in a tighter physical area on the drive vs. being spread out. Fragmented files are accessed quicker due to a shorter range needed to find them.
    It also adds another element of security in the case of a crash of your system partition, your user files will be ok. Some will even use a usb drive or portable hard disk as a home drive.
  • denish
    @denish-iyYTWx Oct 15, 2011
    #-Link-Snipped-# tool helps you easily partition, create, delete, hide, resize the Mac partition or volumes. It helps you manage your Mac partitions and enhance your hard disk performance.
