@thebigk • Feb 7, 2012
Moved to mathematics section.
@ishan-nohePN • Feb 7, 2012
Probability appears to be tough but if you practice it is actually easy. If we can have some problem I will definitely try to solve it.
Meanwhile, I am facing similar type of problem. Earlier (2 days back) I knew a method of finding rank of matrix. But thanks to my good memory I forgot!
What to do? Can we arrange some kind of mathematical debate for solving problems? -
RVignesh OP
@rvignesh-GKAYUU • Feb 7, 2012
for example lets take the word sachin
In dictionary first word is A so remaining words can be arranged in 5! Ways. But we want S , so we will proceed further. Then comes C . Again then remaining words can be arranged in 5! Ways . We will proceed likewise for H I and N
Till now we got 5 times 5! Words . i.e total of 600 words.
So now we get S, as the required word starts from S so we will fix it at first position. Then again we will proceed the same procedure for 2nd alphabet. But fortunately the second required alphabet is A . So we will again fix it. Then comes C but again this is the required word . So proceeding in the same manner we get all the alphabet in the required order.
Hence ultimately we get the required word.
So the rank of word is
5 *5!=600
600+1(the required word)
So if we arrange sachin in dictionary it will be 601st word.
We have a very short method for this . I learnt it when i was in 12th. With that the result can be obtained in 3 or 4 lines. I just forgot that. Please see to that. -
@cooltwins-I5yJpZ • Feb 11, 2012
Taking the example :SACHIN.
First arrange them in ascending order: ACHINS
1) Putting in the first letter in the six letter word : S_ _ _ _ _
The number of letters before S in the arrangement is 5.
and no. of blanks in the word got so far is 5 => 5! ways of arranging letters in them
So as of now the ways are 5* 5!
And the arranged letters become: ACHIN (remove the used letters)
2) Putting in the next letter, A => SA _ _ _ _
But there is no letter in front of A So the sum remains unchanged as 5* 5!
And the arranged letters become: CHIN
3)Putting in the next letter, C => SAC _ _ _
But there is no letter in front of C So the sum remains unchanged as 5* 5!
And the arranged letters become: HIN
and so on... there is no addition of values to the sum after that case.
So there are 5*5! words before it
Taking another example : BANKS
First arrange them in ascending order: ABKNS
1) Putting in the first letter => B _ _ _ _
Number of letters before B in the arrangement is 1
and number of blanks are 4 => 4! ways
So totally right now the sum is 1 * 4!
And arrangement becomes: AKNS (B removed)
2) Inserting A =>BA _ _ _
But since there is no letter before A in the arrangement the sum does not change.
Arrangement becomes : KNS
3) Inserting N=> BAN_ _
1 letter before N and 2 blanks are there => sum becomes 4! + 1*2!
Arrangement: KS
They are in the same order and so just add 1
So, the sum becomes 4! + 2! +1
= 27
There are 27 words before it and the rank is 27+1 = 28
Hope it is clear enough. ๐ -
RVignesh OP
@rvignesh-GKAYUU • Feb 11, 2012
this is an easy one. Thank you very much .๐
But i am afraid this is not the one that i was looking for. But yet this will reduce the work a lot.
Thanks -
@cooltwins-I5yJpZ • Feb 12, 2012
ok... ๐ If you get used to this it is a matter of 30 seconds only. ๐
Will let you know if i find anything else. ๐ -
RVignesh OP
@rvignesh-GKAYUU • Feb 12, 2012
ya definately this is a very good and easy method. Thanks again ๐
@edward-anthony-moreno-3CYq9v • May 6, 2014
why do you add 1 and another 1 in the last part?
@ramani-VR4O43 • May 14, 2014
RVigneshthere are dictionary problems like if the word sachin is to be arranged in a dictionary what is its value. By usual method it can be done but some times it becomes very lengthy , there is a shortcut for this. I forgot that . Can someone please post the shortcut method for it.
I am rather dense.
In my opinion any word of n letters can be represented by a linear matrix of order (1,n). Giving values 1 to 26 for A to Z the matrix can be easily generated.
That for Sachin will be (19,1,3,8,9,14) Sachim will be (19,1,3,8,9,13).
Matrix comparison can be automated in a left to right priority to locate the word in an assemblage of words using a lookup function or some such macro on a database of matrices compiled for each language dictionary.
It is possible that I am completely off base missing some thing in the question -
@abrakadabra • May 14, 2014
Here are some tips and tricks shared by an IIT Professor, Alok Gupta -
Plus here are some simple formulae that a friend shared with me - -
@abrakadabra • May 30, 2023
Let us have examples and you mention the method you use to solve them, some maths expert CEans like CP/CT or others can give an easier method then. ๐
