shear strength of break
engr.khawar
@engrkhawar-BtrBO6 โ€ข Oct 25, 2024
hey, i m final year student of civil engineering.i want to ask you friends that have u any knowledge of shear strength of break.As the bricks are used in load bearing walls.so termoundous shear force is acting on it which break it in shear.so plz informe me if u have any knowlede that how can we improve its shear sttrength.hope you will answer me.๐Ÿ˜€
  • Curious George
    @curious-george-jYK6sj • Feb 16, 2008
    The only thing that comes to my mind would be to insert a thinner rebar type reinforcement into the brick during production.
  • civiLLian
    @civillian-OCsQ1I • Feb 17, 2008
    You can also use steel mesh and insert it into the brick. Or you can use additives into the brick depending what type of brick it is whether clay brick or concrete brick.
  • engr.khawar
    @engrkhawar-BtrBO6 • Feb 18, 2008
    both of you friends good suggestion but it is then very uneconomical.if your ideas are used then more budget will be required.
