servo complication
momin
@momin-Jc6Ioa • Oct 26, 2024
hey guys,
i have just bought a standard parallax servo motor. this motor has the same properties as futaba motors. the problem is when i apply the PWM signal to the motor control pin the motor rotates but not as expected. what i know is that the signal should go high for ( 1 to 2 ms) and then low for 20ms.
1 ms should move the shaft to one extreme and 2 ms should move it to the other one.
am i right? if so what could be the problem.
  • roman123
    @roman123-lHdotm • May 2, 2009
    Try to check that the power supply gives positive voltage. If you provide -5V instead of 5V to the servo, it will rotate the opposite way.
  • shahrul
    @shahrul-Ex12xz • May 6, 2009
    You check the signal on the oscilloscope, is that the signal meet what you need.
  • Rifaa
    @rifaa-NaWZZ4 • May 9, 2009
    @ momin. Post your schematic. then only I can help
