Servlets not running
Ashutosh_shukla
@ashutosh-shukla-ed4Ei4 β€’ Oct 25, 2024
Can you please tell my servlets are not running?
I have J2SE and J2EE installed on my machine.
I have apache tomcat 6.0.18 installed as well.
I think may be i have set the wrong paths.
I want to know all details about the paths to be set for the servlets.
Can anyone help please thanks in advance.
i am πŸ˜”πŸ˜”πŸ˜”πŸ˜”πŸ˜” make me πŸ˜€πŸ˜€πŸ˜€πŸ˜€πŸ˜€
  • mi_pratik
    @mi-pratik-viCidj Dec 14, 2008
    <a href="https://pdf.coreservlets.com/" target="_blank" rel="nofollow noopener noreferrer">Front Page - Coreservlets</a>
    Check this site
    I did a lot time ago that really helped in the servlets part a lot
  • Ashutosh_shukla
    @ashutosh-shukla-ed4Ei4 Dec 14, 2008
    I will check it thanks but any further help is welcome
  • shalini_goel14
    @shalini-goel14-ASmC2J Dec 15, 2008
    Hi Ashutosh,
    Please confirm if your following classpaths are set properly or not:
    1. Default location for tomcat installed is "C:\ProgramFiles\Apache Software Foundation\Tomcat 6.0"
    If it is other than this
    set JAVA_HOME environment variable to <directory in which Java is intalled>
    Default directory for java installed is "C:\Program Files\Java\JDK1.6"
    2. Confirm if lib folder of tomcat contains servlet.jar
    "C:\ProgramFiles\Apache Software Foundation\Tomcat 6.0\common\lib" folder contains servlet.jar .This jar file is required for running servlets.
    3. Check if "C:\ProgramFiles\Apache Software Foundation\Tomcat 6.0\common\lib\servlet.jar" is included in your CLASSPATH environment variable.Because classes required for running your servlet class can be find from here.
    4. Make sure the class file of your servlet java class exist in tomcat's webapps directory.
    5. Appropriate entry is made in web.xml
    Hope,this info will help you somewhere πŸ˜€.
    If still any problem exist,better you show us error-logs or setting you have made in your local machine.
  • Ashutosh_shukla
    @ashutosh-shukla-ed4Ei4 Dec 21, 2008
    I have not written any web.xml file can you please help me out with that one I am giving you my servlet code enclosed here in.
    import java.io.*;
    import javax.servlet.*;
    import javax.servlet.http.*;
    public class abc extends HttpServlet
    	public void doGet(HttpServletRequest request,HttpServletResponse response) throws IOException,ServletException
    		PrintWriter out=response.getWriter();
    		String title="Simple Servlet Output";
    		response.setContentType("text/html");
    		out.println("<html><head><title>"+title+"</title></head>");
    		out.println("<body><h1>"+title+"</h1>");
    		out.println("Hello</body></html>");
    		out.close();
    I want to know is there any way to check the servlet code without writing the web.xml file each time.confused:
  • shalini_goel14
    @shalini-goel14-ASmC2J Dec 21, 2008
    Hi Ashutosh,
    If your above code is not giving any compiler errors,then its ok.But you have to make an entry in web.xml.
    <servlet>
    <servlet-name>abc</servlet-name>
    <servlet-class>abc</servlet-class>
    </servlet>
    <servlet-mapping>
    <url-pattern>/*</url-pattern>
    </servlet-mapping>
    I hope u understand how important this entry is πŸ˜€. Any doubts please specify clearly.
  • Ashutosh_shukla
    @ashutosh-shukla-ed4Ei4 Dec 22, 2008
    Hello, thanks that you are helping but the error is that it cannot find the servlet classes so may be i have set the wrong paths I have checked all the paths they are set as per your saying can you just check my code if it is correct by running it on your platform if possible.I am sick of this error will keep trying to check all paths again but its tuff to find your own errors.Anyways please tell me if code is correect.
  • shalini_goel14
    @shalini-goel14-ASmC2J Dec 22, 2008
    Hi Ashutosh,
    Your code is absolutely fine.Right now I cannot run it on my system.Have you put the abc.class file in webapps folder of apache tomcat ? If not Please create some folder for eg. servletTest in webapps and in it create one WEB-INF folder and inside WEB-INF create one classes folder .Put your abc.class file there.Also create one web.xml in WEB-INF folder.Once done start the server, open the browser enter the correct url then you will get a page displaying what you tried to print from abc.java file.
    If you can get Complete Reference of Java from someone ,better read its Servlet chapter(I guess some 29th-30th chapter in j2se5 edition) . It will definitely solve your problem πŸ˜€.
    PS: A suggestion Please never make a class like 'abc' in java .Its first letter should be always capital.You could make ServletTest.java.
  • Ashutosh_shukla
    @ashutosh-shukla-ed4Ei4 Dec 23, 2008
    Ya i know the naming conventions of Java but the point is not that. I will refer the Complete Reference for help for sure I have a copy of that.Anyways I executed the program on a friends machine I got it sorted out.Thanks for all your help.
  • shalini_goel14
    @shalini-goel14-ASmC2J Dec 23, 2008
    Welcome πŸ˜€. Please share your actual problem and its solution here.
  • cse_200509
    @cse-200509-cGKRTo Jan 3, 2009
    well !!!
    one thing that is missing is that u need to add an entry for your servlet in
    /tomcat/webapps/examples/WEB-INF/web.xml .
    an entry like this is required:
    <servlet>
    <servlet-name>YourServlet</servlet-name>
    <servlet-class>YourServlet</servlet-class>
    </servlet>
  • nileshchakkar
    @nileshchakkar-iD2qYd Jan 3, 2009
    very good descussion by all of you.
    Thanks a lot
