@abhishek-fg9tRh • Nov 2, 2012
Well, I didn't understood what you're trying to ask.
Anyways, I will try to explain both the terms.
Semiconductor is a substance whose width of forbidden energy (also called energy gap) is relatively small ~1eV. So, technically semiconductor is "not a component" which can control the flow of current.
While on other end, Resistor "is a component", which opposes the flow of current.
Even a semiconductor device needs resistor to control the flow of current.
You're just mixing up two different things.
Redefine your question please. -
@thebigk • Nov 2, 2012
This should explain the basic concept of the resistor: #-Link-Snipped-# -
@prototype-G9Gn5k • Nov 3, 2012
A semiconductor device can provide you with dynamic functionality, for eg., a single diode can act as a low resistance or high resistance. There are many other reasons like power consumption, heat dissipation etc. in which semiconductor is better.
TL;DR, semiconductor devices gives you "control ability" over its function which is absent in a resistor. -
@jeffrey-xA7lUP • Nov 3, 2012
Resistor is independent of external controls other than atmospheric effect.
But a FET (Varistor config) has a dynamic control knob in it. This makes it more significant in their applications. That is why they are prefered more
But still for a fixed current to be got from a voltage source we use a resistor as this is simple in design. But in the case of SC devices there are many parameters to be taken into account -
@prashanth463-bHrSPU • Nov 3, 2012
a resistor opposes the flow of current even if any parameter is changed(except the temperature)
but a semi conductor device changes its resistance value with the change in certain parameters, hence we use semi conductor devices more than a just resistor -
Resistors are not 100 % replaced by Semi conductor devices and they cannot be alsoprashanth463a resistor opposes the flow of current even if any parameter is changed(except the temperature)
But to an extent sensitive and Highly stable systems are made using Semi conductor -
yea i know, i was just trying to keep it short
however, thanks for correcting sir -
Hey throw that Sir attitude out manprashanth463yea i know, i was just trying to keep it short
I am just a beginner like you in Electronics 😀
We are born to learn everyday -
very kind of you samuel 😀jeffrey samuelHey throw that Sir attitude out man
i'm a rookie too -
@dossdss-4lCGQo • Nov 5, 2012
i think you are asking semiconductor device based control vs resistance based control (pot)....for example in Fan regulator.
the very prime reason behind using semiconductor based device regulator than trimmer based regulator is power saving.
in resistive fan regulator the excess power is dissipated in heat and much power is wasted...
but in other kind of regulators only required amount of power is taken without wasting it...
