In steel structure seismic force to be considered or not?0
Administrator • Sep 10, 2012
Good question. I'm tagging #-Link-Snipped-# , #-Link-Snipped-# .Sairaj83In steel structure seismic force to be considered or not?Are you sure? This action cannot be undone. -
Member • Sep 10, 2012
Regardless, in which Sesmic Zone and what type of structure you are creating, Sesmic Force HAD to be in consideration to build up structure .
Not sure, if you are talking about any particular type of structure; but for most moderate to big size structures it's law (depending on the sesmic zone, at most part of the world) to consider the sesmic force.
Do you have any particular structure in mind while asking this question?
-CBAre you sure? This action cannot be undone. -
Member • Sep 11, 2012
#-Link-Snipped-# for your reply.Which code to follow for seismic design in steel structure.Yes we are planning for a multistorey residential project in Gurgaon.Are you sure? This action cannot be undone. -
It's been a while when I am doing active structural designing,
Probably it would be the 1997 AISC Seismic Provisions for Structural Steel Buildings. Again, I would ask you to recheck the code.
Member • Sep 15, 2012
It is in UBC 1997 and it should be considerated...Are you sure? This action cannot be undone. -
whwere are you from? Gorguon? what country?Sairaj83#-Link-Snipped-# for your reply.Which code to follow for seismic design in steel structure.Yes we are planning for a multistorey residential project in Gurgaon.Are you sure? This action cannot be undone. -
sorry
let me know if you wnat further explains. this is my job and I can help you....Are you sure? This action cannot be undone. -
aliasghar@ if you have any materials regarding seismic analysis in steel structure please share itAre you sure? This action cannot be undone. -
sairaj 83Sairaj83aliasghar@ if you have any materials regarding seismic analysis in steel structure please share it
hi
theer is two different method for analyzing seismic effect in ETABS. static analysis & dynamic analysis. for the first one you just need to have C (X) & C(Y), ( C= ABI/R), but for the secned one you need to know how to find e besic vertical load (V=CW, W is building weight) and other floors vertical loads..
if you have specific problem Im be glad to help you solve it...
aliAre you sure? This action cannot be undone. -
Member • Sep 16, 2012
In India for seismic design IS 1893 is used. for ductile detailing of structures IS 13920 is used.Sairaj83#-Link-Snipped-# for your reply.Which code to follow for seismic design in steel structure.Yes we are planning for a multistorey residential project in Gurgaon.Are you sure? This action cannot be undone. -
Member • Nov 3, 2012
steel structures like any other structures and seismic calculation apply according to zones in your design codeAre you sure? This action cannot be undone. -
Thanks all of you for your response.If anybody have model steel structure building in Etabs then please share it.Are you sure? This action cannot be undone.
