Securing wireless router network
Priyalak
@priyalak-wg8tV6 โ€ข Oct 25, 2024
Hello friend
I have got a query. I have installed a wireless router at home. At a time 2 people can access the net using it. At present only one wireless port is under use. I would like to make sure that the network is secure. I meant to say that I would like to make sure that no one else uses this service other than me when the router is switched on. How can I ensure this? A few people are residing in 10m distance from it. Please help.:sad:
  • PARTH.DP
    @parthdp-6sK25U • Jan 6, 2009
    you can secure your network.simply connect to the ip address of tour router.go in the security menuand keep password protedted .i did this for my wi-fi network.best of luck.
  • Priyalak
    @priyalak-wg8tV6 • Jan 6, 2009
    Thank you for that piece of information. ๐Ÿ˜€
  • ashuashi
    @ashuashi-Z4179a • Jan 7, 2009
    PriyalakHello friend
    What router you are using? You need to login to the router through its IP address. You can find the same in its manual - most probably. User the user name - admin (default access) password - admin or password in some cases. You can enable the security feature by giving your own password to access net through wi-fi. Also you can change the settings of connecting multiple users thru wi-fi if required by enabling the ip-addresses.
    hope it helps, ;-)
    regards,
