scripting language
sai krishna
@sai-krishna-mCwaOF Oct 26, 2024
hi all,
i feel glad to post my first thread.can anyone explain me what is meant by "SCRIPTING LANGUAGE" .
i have learnt that java script is an "interpreted language".
what is meant by "interpeted language"?
thanks in advance.
  • Elisa
    @elisa-4hps94 Dec 6, 2007
    Scripting language is simply a programming language. Normally, a scripting language needs an Interpreter to work (not compiler). Since compilation of the code is not a mandatory step, any change to the code can be immediately reflected.
    Yes, JavaScript is an interpreted language. As I said above, JavaScript needs an interpreter to execute.
  • sai krishna
    @sai-krishna-mCwaOF Dec 7, 2007
    ElisaScripting language is simply a programming language. Normally, a scripting language needs an Interpreter to work (not compiler). Since compilation of the code is not a mandatory step, any change to the code can be immediately reflected.
    Thank u elisa.can u breifly explain me the difference b\n interpreter and compiler.
    I think both are meant for translating the source code written in some language into machine understandable language.
    Am i correct.if not please correct me.
    Thanks once again.
